Good Morning Jody, thank you for your post!
If your Electrolux microwave (EW30M055HS) has power but does not heat, often the possibilities include one of four culprits:
·Power Supply
·Plugged into GFI Outlet
·Faulty Control Panel
·Faulty Magnetron
I always recommend resetting your microwave first. You can do so by unplugging your appliance or flipping the circuit breaker for about 30 seconds and then turn your microwave back on. If your microwave stills does not heat or turn, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area.
SOURCE: electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
I appreciate your post, friend!
Based off the information you have provided your Electrolux built in microwave is displaying an error code of "ECON". I am showing that this is an invalid error code. I would recommend you perform a reset on your microwave and you can do that by disconnecting the power cord for roughly ten minutes. If that does not help correct your issue I would suggest contacting a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
