I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU.
I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical
characteristics than VHS. These formats were never developed with the
intention to be mechanically compatible with past or current VHS
technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine.
Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
To the best of my knowledge 8mm VTR's have not been available for some time now. On the other hand there are plenty of Hi8 cameras and players available after market. eBay is a great source. Keep in mind that Hi8 cameras and decks will also play standard 8mm video tapes. There are also many video tape transfer services that will transfer your 8mm tapes to DVD or other formats of your choice. Just Google "videotape transfer service"
Yes...First chose the appropriate Record Quality based on the total length of all 3 videos you want to transfer. Next using a RCA component cable, connect the Yellow, Red and White from the Hi-8 camcorder to the DVDirect RCA inputs. After each tape has finished, just press the red record button...Press it again when the next tape your want to record begins. When all are done prrss the stop button (small button above the record button) and finalize as normal.
only sony really supported 8mm look for any trv model cam on ebay etc and make sure you tapes were hi 8mm-not digital 8-digital 8 won't play on reg 8mm cam-need to get model that supports both formats then-trv480-look at tapes and if they say digital and/or hi 8 they may have been in digital and get the 480 it will work with both types
Sony handycam model starts with CCD-XXXX shows that its analog camcorder and its picture signal is analog. You can't connect directly camera with PC to transfer files. You need to install MPEG card or some thing like that in PC 1st and this card will digitize analog picture signal into compatible format.
I have the same issue myself with my gillion of family tapes and my Hi8 unit broken! The only remedy I have found is to either invest in a new lower price HI8 unit, rent a unit and get my transfers done, or pay to have the old tapes put on dvd professionally. None of these options are too appealing to me, but really seem to be the only options available. If only HI8 had an adapter like VHS-C! I personally would look on some of the online resellers to see if you can obtain a unit that is lower priced to meet your needs. Investing overall in a Hi8 as your only camcorder is not advised, due to it being almost obsolete technology.
Do you have another video camera that will hook up to your computer? In the past, I've connected my old Hi-8 to my Mini DV, recorded the footage from the Hi-8 to the Mini DV and then digitized on the computer from the Mini DV. You will however need some video software like iMovie for this solution.
You can also, hook the Hi-8 camera up to a VCR or TV using the appropriate cable and view it that way.
