Zebra Symbol MK500 Data Terminal Logo
A
Anonymous Posted on Oct 30, 2013
Reset mk590 how to reset symbol mk590
1helpful
2004 saturn vue service light on with wrench how do I reset
which service light with wrench their are two of them 01 is inside a car symbol the other is next to an oil container symbol if first on vehicle needs service its also like a check engine this one can turn on for abs-transmission-etc have vehicle scanned for a trouble code --the other is oil change or service reminder both symbols are on page 3-39 and 3-40 of your owners manual the first symbol advises to see a dealer to review the trouble code and page 5-20 explaines how to reset oil change/service light --turn key to on/run position not start and push accellarator 3x and system will reset the following link is owners manual
2004 Saturn VUE Owner Manual
2helpful
Factory reset ftm symbol shows instead of hp symbol
Plug the supplied charger in to the TP and into the wall. Then hold the power button and the button at the bottom of the screen simultaneously. After about 10 - 15 seconds the TP reboots.
1helpful
2answers
I need reset the default password for a symbol WS5100
Forgot your Windows password? A Windows Password Reset Disk could do all the job for you, it can reset your lost or unknown Windows password safely and quickly without login, you can create a Windows password reset disk with the tool Windows Password Breaker, then use it to reset your password.
5helpful
2answers
How do i reset the service spanner symbol on my aprilia 125 leonardo sport city scooter
Ok, disconnecting the battery does NOT reset the service light. To reset the service light (spanner symbol) on dashboard you must hold the mode button for about 5 seconds with ignition OFF then while still holding the mode button turn ignition on, continue holding the mode button for a futher 10 - 12 secs and then it should just disapear. This solution was brought to by RPMs. Mobile motorcycle service.
6helpful
3answers
Wrench light is on and odometer shows negative mileage
The negative number means the car should have had it's oil changed that many miles ago. Oil life starts at 100% for new oil & counts down every 10%. At 15% the display will always show, which means it's near time to change the oil.
usersteve83, your oil may have been changed but the timer not reset. Reset the timer as shown...
1. Turn ignition to the "ON" position. (do not start engine)
2. Press SEL/RESET repeatedly until the oil life indicator is displayed.
3. Press & hold the SEL/RESET for about 10 seconds until it blinks then let go of the button.
4. Press the SEL/RESET again for about 5 seconds or until the oil life indicator resets to 100%.
Wrench = Maintenance Minder: Symbol letter & number...
Symbol A - Relace engine oil.
Symbol B - Replace engine oil & filter, Inspect front & rear brakes, Check parking brake adjustment, Visually inpest the tie rods, suspension components,driveshaft boots, brake hoses & line (including ABS), all fluid levels & their conditions, exhaust system, fuel lines & connections.
Symbol 1 - Rotate tires.
Symbol 2 - Replace air cleaner element (dusty conditions every 15K miles) & replace dust & pollen filter (behind glovebox) every 15K miles if mainly dusty or city driving.
Symbol 3 - Replace transmission fluid.
Symbol 4 - Replace spark plugs.
Symbol 5 - Replace engine coolant.
All above are taken from the 2006 Civic EX owner's manual.
2answers
How to hard reset my symbol scanner (model #: PPT 2846)
Hello - you may need a board level repair:
Let me know if you need help with this
Ian
DC Solutions
[email protected]
1helpful
After reset MC50
try hard reset... 1+9+power button
Top Zebra Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
