SOURCE: I recently bought a Nvidia GeForce 6200 256Mb AGP
Sounds like a Driver Conflict.
Still have the old 5200 drivers in there?
Did you install the drivers for the 6200, BEFORE you physically put the graphics card in? (Not shouting)
Let's say you did remove the 5200 drivers, before you installed the 6200 graphics card.
BUT,
If you physically install the 6200 graphics card, BEFORE you have installed the drivers, Windows 'sees' a new device, and hurries up to match one of it's generic drivers.
(Windows has thousands of drivers!)
Now you come along, and install THE drivers for the 6200. Windows has a drivers conflict.
Windows: "Which drivers do I use? These, or THESE?"
Makes for a garbled graphics display as you've described.
If the above is true, start over.
Go to Add/Remove Programs, and Remove the Nvidia software. All of it that has Nvidia next to it.
(THIS, is provided of course, that the computer HAS Integrated Graphics, and does not just use a graphics card. You will be plugging the monitor, into the VGA port in the I/O area, on the back of the computer temporarily, if this is true, and this computer has Integrated Graphics)
(Start>Control Panel>Add/Remove Programs) If there is more than one Nvidia program listed, Do No restart the computer each time you remove one. Do Not restart. Read on)
After all Nvidia software has been removed, close Add/Remove Programs, close Control Panel, and return to the desktop screen.
Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Unplug the computer from power.
Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. (Count, 1001,..1002,..1003,..1004,..1005) Let go of the Power On button. Do this procedure Two more times.
What you are doing is clearing any CMOS Error Codes, and resetting BIOS back to the factory default settings.
Open the case. TOUCH the metal frame of the case to relieve your body of Static electricity. Remove the 6200 card. Plug the monitor into the back of the computer into the VGA port. Leave the case open, you'll be going back in there.
Plug the computer into power. WAIT 1 minute, then turn it on. After Windows has fully loaded, install the GeForce 6200 drivers from that CD disk. Do Not restart.
Shut down normally.
Unplug from power. Touch that metal frame again. Install the GeForce 6200 card. Close the case. Plug the monitor into the GeForce 6200. (You did plug the monitor into the 6200 the first time, right, and not the VGA port?)
Plug the computer back into power. WAIT 1 minute. Turn the computer on. Go to Start>Nvidia>Nvidia control panel, and set the settings.
SOURCE: Can anyone please tell me if my video card is a
Tech Specs
CineFX 3.0 Shading Architecture
64-Bit Texture Filtering and Blending
Intellisample 3.0 Technology
UltraShadow II Technology
TurboCache Technology
PureVideo Technology
Advanced Display Functionality
Advanced Engineering
NVIDIA® Digital Vibrance Control™ (DVC) 3.0
Operating Systems
API Support
GeForce 6 Series GPUs Features Comparison:
Feature
GeForce 6800
Models
GeForce 6600
Models
GeForce 6200
Models
GeForce 6200
w/Turbocache
Microsoft® DirectX® 9.0
SM 3.0
SM 3.0
SM 3.0
SM 3.0
Graphics Bus Technology
AGP 8X/PCI Express
AGP 8X/PCI Express
AGP 8X/PCI Express
PCI Express
NVIDIA® Intellisample™ Technology
3.0
3.0
3.01
3.01
NVIDIA® SLI™ Technology
X2
X2
n/a
n/a
NVIDIA® PureVideo™ Technology
X3
X3
X3
X3
NVIDIA® TurboCache™ Technology
n/a
n/a
n/a
X4
64-bit Texture Filtering and Bending
X
X
n/a
n/a
Effective Memory Interface
256-bit
128-bit
128-bit
128/64-bit
Memory
GDDR35 and DDR
GDDR35 and DDR
DDR
DDR
Process
0.13 micron
0.11 micron
0.11 micron
0.11 micron
RAMDACs
400 MHz
400 MHz
400 MHz
400 MHz
1. GeForce 6200 models do not include compression technology.
2. NVIDIA SLI: Available on SLI-certified versions of GeForce 6800 Ultra, 6800 GT, 6800 GS, 6800, 6800 XT, 6800 LE, 6600 GT, 6600, and 6600 LE PCI Express GPUs only.
3. Features may vary by product. Some features may require additional software.
4. Available on select GeForce 6200 models only.
5. GDDR3 - GeForce 6800 Ultra, 6800 GT, 6800 GS, and 6600 GT only.
SOURCE: where i have a installation Nvidia GeForce FX 5500
You can download the video card driver from this link
http://download.cnet.com/NVIDIA-GeForce-FX-5500/3000-2108_4-64419.html
SOURCE: i need Nvidia GeForce 6600 / 256MB DDR / AGP 8x /
I would suggest this instead,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4803129&CatId=2234
It will far surpass the graphics quality of an Nvidia GeForce 6600 series graphics card, and will use less power.
If the above specifications are for a particular game you're trying to run, this video card excels past the minimum required specifications for the game.
1) Has 512MB of GDDR2 ram memory
2) 128 bit Memory Interface
3) 120 Stream Processors
4) Two DVI port ports
5) TV-Out (S-Video) port
Doesn't matter if you use an Nvidia graphics card, or an AMD ATI graphics card on your computer.
What matters is if it is an AGP graphics card, (It is), and an AGP 8X graphics card. (It is)
Regards,
joecoolvette
