Let me say sir, you are a smart fellow!
this is the first post ever with a location (thanks)
2005. hummmmm and a started year , thanks 2 times.
CD type A or B (be is the changer option?)
as you may not know, CD players of all types evolved
first came CD-DA (audio discs )
then came , recordable disc that you can play.
then files, playing files of many times. MP3, and near endless updates to 2013.
and DVD, as you know there are no DVD-DA.
so they added the abiltiy to read, DVD with files.
id bet the head end audio , cd in your car varies by country.
I bet NIzzan puts diffent heads in different countries, this is near impossible to track. (ask nissan)
but to be sure, you can tests your CD.
if it dont play any DVD with MP3s on it , its not ever going to.
buy a new radio/CD/DVD with USB stick port. ($100 in uSA)
and then put your audio on the USB stick and forget DVD forever.
see all formats here, huge.
http://en.wikipedia.org/wiki/Compact_disc
ok , i google your cars , operators manual
it stats only disks marked CD-DA work.
and says, no CCCD, no CD-r , no CD-rw work.
and need not say DVD as it dont do those because they are never CDDA.
new radio time.
SOURCE: nissan murano 2005 sl keyless entry remote programing
Close all vehicle doors, LOCK doors using drivers side switch.
Insert key all the way into the ignition, (do not turn) remove key.
Repeat this step 5 times. (6 total)
Hazards should flash to indicate program mode.
Press any button on transmitter to be programmed, hazards should flash to indicate successfull program.
*For additional remotes, cycle drivers door lock UNLOCK, LOCK, press
any button on remote, hazards should flash. Repeat step as necessary.
Ignition ON, (engine off) ignition OFF, UNLOCK using drivers side switch, test remotes.
Source
SOURCE: '06 Nissan Murano factory radio/cd player removal steps
what holds the radio in place besides the 2 side screws in a 2006 nissan murano
SOURCE: Replace rear wiper on 2005 Murano
You probably already figured this out, but you have to remove the wiper arm completely in order to replace the wiper blade.
The blades are an unusual size (somewhere around 14 1/2") and I believe they are only available from a Nissan dealership. They include printed instructions in the box but just in case, this is from the official Nissan service manual:
SOURCE: How to Remove Car Radio from Nissan Murano
If you disconnect one of the battery cables for about 30 sec and reconnect it, that will reset the CD player. Then you can put in the key and see if can eject the offending CD. My bet is that it won't. I own a 2006 with a failing CD (getting it replaced on warranty next week). The CD player in these cars is a real stinker. Nissan should be ashamed.
SOURCE: how do i reset my check engine soon light 2005
you can buy a code reader from an auto parts store that will give you the ability to reset the check engine light, or most parts stores have one that they use on customers cars at no charge. if you ask them to read which code your car is throwing, most of them will let you hit the button to clear the code. they aren't supposed to do it themselves for some reason, but from my experience they will let you.
