When typing a text, I can't pick the letters or numbers I want.
Nokia 6085
When texting, everytime I press a button something is typed. If I press the 3 key 3 times to type a F, it types Fee with a line below it. Help?
Re: When typing a text, I can't pick the letters or...
That means your messaging font is set to type the word for you. find "options" then look for soomething that ays "abc" your phone is set to type in "t9"
Welcome to Fixya. If you want to undo the preddictive text just follow the guide below.
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on Entry SetUp
3. Select the Primary Set Up or Secondary Setup by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
ITAP: it's a built-in software which predicts the word you are typing. THIS IS PREDICTIVE TEXT
TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter F press the number 3 button three times.
Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
To change from one mode to the next you can select it by pressing the top center button from a text entry screen, and Press on Entry Mode. Shortcut: you can press the # key on your phone when you are writing a message and you will see abc1 for your primary mode, 123 for numeric; @ for symbols; and abc2 for your secondary mode.
If you have questions please let me know. Thanks for using Fixya.
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
How to set up Text Entry Mode? 1. From any text entry screen (ie. when you are writing a text
wheel.
2. Press on "Entry SetUp"
3. Select the "Primary Set Up" or "Secondary Setup" by choosing
keys multiple times. Ie. for the letter "F" press the number 3 button
three times.
Hi, Hi-Tech people! I got a Motorola RAZR V3, my problem starts when everytime I press the keys to type a message...it HANGS. Once it HANGS, I can't type anymore and continue the message I suppose to write. It wont move no more. It just STUCK-UP right there on the last letter I'd pressed. I have to take-off the battery at the back to re-start the unit again. Then, start typing again...same thing happens. It just HANG by itself and I can't press other keys no more.
Any HELP?
MannyQ
