Hi. Pay careful attention to the way the end of the film fits through the take-up reel. Open the back (empty) and give the wind knob a few twists. That will tell you which way it is turning. Put the end of your film through the slot in the take-up reel so itd winds onto itself as it advances. There's usually enough extra unexposed wound onto the factory reel that it won't cost you and pix at the end of it. Pull enough out of the cassette to be sure your winding-load position is really going to hold when you advance. Good luck.
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from: http://www.lensinc.net/manuals/Nikon_N6006L.pdf
This won\'t be easy for you if you don\'t the proper tools, You have to remove the wind lever assy, and the speed dial, Then wind side top cover, Then pull wind base plate assy, And check counter reset lever, to make sure spring didn\'t come loose, Putting the baseplate back on can be fun because of linkage to the wind assy
Just put the film cassette in as you did in your manual camera, pull the leader over toward the takeup spool, just to the red mark - no further. Then close the back and it'll wind automatically. If it doesn't, turn the power switch on-off-on.
First, replace the batteries, turn on the camera and try again. If that dose not work, you need to take the camera into a darkroom, a room that is 100% totally dark. The slightest light leak could fog your film. If you do not have a room in your house that you can make light tight during daylight, try doing this at night, Once you are in the darkroom, you will need to work by feel. Open the camera back and feel for the film magazine. If there is no film protruding, you are ok and can turn on the lights. If not, you need to pop the magazine out and use the protruding knob on the end to manually wind the film into the magazine while you alternately pull the film off the take-up spindle. Once all the film is in the magazine, you can turn on the lights.
Sept 19th, 2008
On the bottom of the Nikon FE, there is a silver button to push in, and this releases a lock for the film.
Then on the left side, on the top, there is a white arrow and a silver lever tucked in. Wind your film, this it's all the way back in the canister. Then the black lever by the speed film (ASO) numbers, pull that back toward you. This will release the black 3/4" knob upward, and by gently pulling this upward, your door will release and the film canister will be allowed to come out. Just besure to wind your film back in the cansiter, before you open the door, or your photos will be over exposed. Best to do this in a darker area or shaddowed area, just for protection.
Good Luck. I've had mine since the mid 1970's and love it for double exposures and the special filters I have for it. The Hot Shoe for the flash attachment, just burned out on me a couple of days ago.
