Dell Dimension 4400 does not post nor boot
Check power supply in back to see if you have on and off switch but you would'nt be the first with this problem from dell about the power supply going out meaning:
if you don't have nothing happening when your trying to boot the computer then it's the power supply, plug in computer power up and feel in back to see if the fan is blowing if nothing power supply is gone call dell.
remove all cards and memory disconnect monitor..and try to boot..if it boots replace one thing at a time to you find what is cutting it out..
if you remove everything and power supply comes on but you don't hear nothing from board are see the light on the board...
the mother board is fryed...
ok buddy tryed to find something for you I know it must be a pain in the **** I had the same problem with my memory on a dell also and I downloaded the bio's fix and it worked..lets see if it works for you...go to this site it's Dell's everything to do with your computer updates they came out with for that machine and board and other things..but download the bio's update first...and try that just click on it and deside what way you want to go one is to floppy and the other is to harddrive seeings you can't see it yet and get no were try the floppy to bio's let me know ok...have'nt gave up on you..moe...
http://support.dell.com/support/download...
I'm not sure why but it has something to do with the memory I know this having the same trouble before but all I did was remove the sticks of mem and change slots and it worked find for me and never went out again..try and check with dell the memory they used when it came out it should be on your link I sent you the spec...are the phone number to call I'm sorry but I'm at a loss on that one but I'm also 100% that it's got to do with the memory...good luck and again I'm sorry we could'nt get it..
Suggested Resolution
Solid green
Power is on, and the computer is
operating normally. On the desktop computer, a solid green light
indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Used power supply tester...all power is fine. I get no beeps and no post on monitor. Tried several graphics cards.
I can see lights but no beeps. Can hear and feel fan operations. When hard drive is installed can actually hear it power up. I do not hear or see and ram post activity. Have tried three separate sticks of ram. All are supposed to work. Acts the same even with all items removed. With no ram it does beep.
I got the bios on a floppy and tried to boot but I saw nor heard anything other than the floppy drive power up. Any more thoughts?
