New World G60m Gas Single Oven Logo
Anonymous Posted on Aug 05, 2013
FLAME FAILURE - New World G60m Gas Single Oven
My main gas oven will light but not go up to full flame, the top oven works fine
Flame failure device not working heater pilot could be blocked
Oct 24, 2016 • Ovens
1helpful
My oven ignite when i press the knob for 6 second to make it work after i release the knob it turns off
There is a safety thermocouple that requires the gas to be running a flame to keep going. Its called the "flame failure device". Yours is not working. Talk to an appliance engineer.
Nov 02, 2014 • Ovens
How do I fix a flame failure device
Assuming a modern electronic device here. Flame failure detectors work by sensing the current flow through the flame to ground. Only repair is to repalace the electronic sensor module.
On older systems, a thermal couple is used. A small copper tube, sealed at both ends is situated in the flame. As the liquid inside the tube heats up, it explands and opens a valve at the other end, letting more gas flow. If the liquid leaks out, the expansion does not happen and the gas valve stays closed. Thermal couples are available at most home hardware stores and simply unscrew from the valve side.
Place the other end directly in the flame of the pilot light.
Apr 07, 2014 • Ovens
2helpful
Canon Carrick LPG cooker-failure of full flame control bottom oven I have had this cooker for 14 months and used it for 6 months only from new. The bottom main oven has just started to play...
I had the same problem. I solved it by re-attaching a device which had come undone. On the right hand side of the burner is a rod with a metal wire attached. This was lying loose. It should be fixed to a little grey clip which is itself attached to a a piece of metal. By re-fixing the clip and the rod to the clip it solved the problem. Hope this helps. I have photos of how it should look. email [email protected] for a JPG.
Dec 01, 2010 • Ovens
How do I fit a Flame Failure Device into a Mistral EL
you should not attempt to repair this unless you are gas registered. It is against the law!
Oct 21, 2009 • Ovens
ICV-1
If you could narrow down the buzzing noise, where and when, it may be significant.
As far as the unit losing its flame, I believe this unit uses a "flame switch" to prove there is a pilot flame. (Part# 1133) So first visually verify the flame quality and the position of the bulb for the flame switch. And assuming that's fine, you need to check the electrical switch portion of the part. It is in the control cabinet towards the bottom. Just two wires.
Usually this problem is a switch failure, rather than a lose connection, or a poor pilot flame. Good luck
Top New World Ovens Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a New World Oven Expert? Answer questions, earn points and help others
