Are you saying it will not start, or will not crank ?
It won't start or crank. Turn the key all the lights come on like normal but don't do anything. There is a slight clicking from the top of the motor.
Could be the neutral safety switch which is part of the transmission select switch. Check and see if you have power at the starter posts with the key switch in the start position. And try cranking it in neutral.
Tried that and still nothing
SOURCE: sometimes it won't start, just
if your power going to starter from ignition switch ,your starter has to be faulty or main wires on starter has bad connection
Check the neutral safety switch on the transmission. It should have three wires on the connector (if I remember correctly). There should be power on the Brown with yellow wire with the key in the crank position. If there is ground that wire and see if the van starts. If it does replace the switch. If it does not check the starter relay.
Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
SOURCE: Replaced the starter and had the battery checked out starter still won't engage
It is probably your cellinoid try jumping your starter
How to replace your 96 Accord LX 2.2L distributor
click this link to watch step by step --> http://adf.ly/Hb4fX
SOURCE: replaced ignition cylinder now starter won't engage
Get a meter and see if starter is getting 12 volts,if not,your inline fusible link is blown.
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
Car starting issues?
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
Car Starting Problems
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in
few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
http://www.howtorepairguide.com
These will help.
Thanks.
CAR NO START PROBLEMS:-----
It
From
Won't Start?
few seconds?
Blows?
start?
These will help.
Thanks.
