Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
Posted on Mar 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TECUMSEH ENGINE PROBLEM
I HAVE A OLDER AREINS SNOWBLOWER WITH A TECUMSEH ENGINE AND HAD TROUBLE WITH THE CARB WOULD NOT GO INTO FAST TROTTLE IT WOULD SOUND LIKE IT WAS BACK FIRING SO I REPLACED BOTH NEEDLES AND PUT A NES SPARK PLUG AND THE IT RAN GOOD SO I STARTE SNOW BLOWING AND ALL OF A SUDDEN THE ENGINE QUIT NOW I CAN'T START IT I CAN'T PULL THE STATER ROPE AS IF THE ENGINE IS SEIZED
Anonymous
Level 2:
Scholar:
  • Expert 76 Answers
  • Posted on Mar 25, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
76
Questions
0
Helped
72450
Points
162
First check the oil and make sure that ti is full. Then remove the spark plug wire and spark plug, then take the recoil cover off and with a socket to fit the flywheel bolt and a breaker bar, try to rotate the engine by hand. Also while you are trying to rotate the engine have someone take and spray some penetrating fluid like seafoam (you can get seafoam from some auto parts stores) don't spray to much, just enough to coat the cylinder wall, and a wooden dowel that just fits in the spark plug hole and log enough to hold onto while inside the head tap on the dowel with a hammer to try to free it up. If it frees up spray a little more seafoam into the cylinder then put the recoil cover back on and pull it over a few times to lube the cylinder wall. If it does not turn the I recommend bringing it to a reputable repair shop. They may be able to free it up or if it is real bad they may be able to help you get a used or new motor for it. Hope it works for you.
Engine surging
you could have leaking head gasket
2helpful
Tecumseh engine snowblower, will only run if I keep pushing the primer bulb, Why?
Take off the screw that holds the carburetor bowl on and clean the holes with a needle and blow air through them. These holes feed gas from thr bowl into the carb and may be clogged.
1helpful
2answers
Tecumseh 10hp snowblower
Sounds like carburetor needs a good cleaning.
1helpful
Engine will not run/tecumseh enginelstall once it starts/hsk model
I assume this is on a snowblower?
Be sure you have fresh fuel.
You can also remove the bowl on the carb and spray carb cleaner in any orfice you see.
Always store a snowblower with fuel stabilizer in it. Otherwise it the fuel can "varnish" the inside of the carb and cause problem.
If it still doesn't start check compression.
Upon starting engine screams then idles down but doesn't have power to run snowblower
SOUNDS LIKE YOUR GOVERNOR LINKAGE IS NOT ADJUSTED RIGHT , OR YOUR THROTTLE SHAFT IN THE CARB IS BINDING.
I have a older areins snowblower with a tecumshen engine and the screw that holds the lever to the linkage oh the block came off hold do you readjust the governor with the trollte wipe opne should the...
whithout the engine running the gov should be trying to full throtle. when started this should tell the carb to supply or restrict fuel/air to compensate for load or the lack of. but to answer your question....yes the gov should be wide open, unrunning.
Engine surges after warm
If your engine has an adjustment screw on the bottom of the carb. try adjusting that at high idle first also if you have a low idle screw. If that don't clear the surging than you might have to take the carb. off and clean it. If cleaning the carb. out dose not do it you may need to put a new carb. kit in. Any questions feel free to ask.
Top Troy Garden Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Troy Garden Expert? Answer questions, earn points and help others
