Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
Posted on Mar 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My F480 doesn't ring when called
My brand new F480 calls out ok but goes straight into voicemail without even ringing on incoming calls - can anyone help?
Fahad I MEMON
Level 2:
Sniper:
  • Expert 129 Answers
  • Posted on Mar 23, 2009
Fahad I MEMON
Expert
Level 2:
Sniper:
Answers
129
Questions
0
Helped
68473
Points
429
Go to call settings and cancel all the call settings information..
note: you will see call barring , call forwarding, call waiting options
just cancel all of them if it will not work, in the phone settings look for the answer call and change the settings there
I need to extend the length of time my phone rings on incoming calls
Hello, Mary -
I checked the user manual for your Alcatel 3003G cell phone:
https://www.manualslib.com/manual/1150047/Alcatel-Tribe-3003g.html?page=1#manual
I did not find any information regarding increasing the length of time of rings of incoming calls in the manual. So, I thought the incoming rings length of time may be dependent upon your cell phone service provider, Vodafone.
I found some information on a Vodafone Support page:
https://support.vodafone.co.uk/
How to increase the time before a call goes to voicemail?
(Quote)
Your Vodafone mobile is set to ring for 15 seconds before going to voicemail. You can change how long it rings for, choosing from 5 to 30 seconds in 5-second intervals.
To choose your desired ringing time:
  • Enter **61*121*11* on your Vodafone mobile
  • Choose the number of seconds you'd like your phone to ring for, followed by #
  • Press Call
  • A confirmation message will pop up on your screen with your new ring time
For example, if you want to set your Vodafone mobile to ring for 25 seconds, you enter **61*121*11*25#, and press Call. When the message pops up, you'll know it's all done.
Watch this simple video to find out how to increase the time before a call goes to voicemail.
https://youtu.be/rGJNpaaD5z8
(End quote)
Best wishes.
Mobile phone,all incoming calls go to voicemail,without ringing
you did not provided what brand, model and year, therefore you need to read your manual...
you need to find in your setup section and enable calls, setup as to re-direct to voicemail after say 5 rings, enable ring.
unfortunately without model and year - more detailed directions cannot be provided...
Feb 08, 2015 • Cell Phones
Hi I have a Panasonic cordless phone kx tg2511al. I sometimes find that incoming calls go straight to voicemail without it ringing first. How do I make sure it rings at least a good number of times...
Remove the battery and allow the set to phone to reset. Now check for the ringer setting at teh back of the base phone to be set to the maximum rings, there can be three settings.
Some times this is also set on the menu.
Connect and test the timing to confirm
Jun 13, 2011 • Cell Phones
The problem is every incoming call rings once then goes straight to voicemail before i can answer
Please check if any call divert or incoming call barring (found at settings menu) are actives .
2helpful
3answers
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
1helpful
Ring 3 times then goes to Voicemail
Does the phone actually ring 3 times. I was having the same problem I was informed that it was not even going to my phone. When I had this same problem T_Mobile could not fix the problem using the 3 g network. If you shut off the 3g feature your problem will go away
Jan 12, 2009 • HTC G1
My new Razor will not ring
do a master reset and clear of the phone
1helpful
Incoming calls
i would got into your voicemail settings and check to see if you have it set to ring once then straight to vmail.. i'm not sure how your phone is set up completely but i would assume you can adjust the amount of rings before vmail picks up.. is this phone new to you?
hope this helps..
d
2helpful
4answers
Length of time phone rings with incoming calls
get your mailbox number then type in **61*44then mailbox mumber*11*then a two digit number between 00 and 30 (seconds delay).
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
