The small socket that the charging cord plugs into on the Tabeo is broken loose and the unit cannot be charged. Bought in Dec of 2012 can this be repaired and is it worth repair?
Hi! Hope this may serve as a hint. When power problem dooms to any electronic device needing battery operation we sometimes least assume that the battery life is near to its end. I mean its charging life has come to end. However, you can sometimes recycle it's life cycle by discharging fully and recharging fully without using it. Battery utility softwares can help monitor its life but cannot revive at all. Charging also using fast charger and or slow charger can help reactivate the battery cells. I personally experience, a gadget of mine its charging life is almost come to end and when I accidentally plug it on my laptop with 3.0 USB offline charging capability it somehow raise its life but not as good as it is. If the above doesn't work at all, it's time to change the battery pack. Goodluck!
Hi
It will not charge. Are you sure that the battery is OK?
Do you charge the tablet with electricity or via USB?
You have checked the cord and wire into the the plug and the plug itself. Is it possible for you to borrow a charger to find out if it is the battery that is not working.
All the best
Kolbrun
THIS IS THE SAME PROBLEM I HAVE. I JUST POSTED 5 MINUTES AGO. UNFORTUNATELY MY HUSBAND THREW AWAY THE ORIGINAL BOX THAT IT CAME IN. PLEASE LET ME KNOW IF YOU FIND ANYTHING OUT. THANK YOU, NICOLE [email protected]
So its a time traveling device also? ;) I assume you mean Dec. of 2012. It should have a 1 year manufacture warranty on it. I would call Toys R Us customer care and have them warranty it for you. 1-800-ToysRUs
I spoke with someone in their Tech department today about another problem and mentioned that I was having problems with it charging and he said that when I get back the device there is an update that needs to be installed in regards to the charging problem. So when you get a chance install all updates.
