Life Fitness 9100 Next Generation Remanufactured Treadmill Logo
Paul Staddon Posted on Mar 30, 2013
How do i refill the wax on my life fitness 9100 treadmill?
sajeel1978 .
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 44 Answers
  • Posted on Nov 05, 2013
sajeel1978 .
Contributor
Level 1:
New Friend:
Cheetah:
Answers
44
Questions
Helped
13604
Points
53
Open cover on left at rear of treadmill, disconnect pipe, fill with wax kit and then reconnect pipe, 2 screws to remove wax cover.
3 Related Answers
vpaaf
Howard
  • 115 Answers
  • Posted on May 01, 2009
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on Apr 12, 2010
SOURCE: I have a life fitness treadmill and put new wax in
you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Oct 18, 2012
SOURCE: I have A Life fitness 9100 treadmill The display shows the message
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Add Your Answer
    2answers
    Lifefitness treadmill belt sticks even though wax bag is fulll
    alot of times you have to remove the wax spray nozel and clean as the wax hardens over it
    I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
  • 0helpful
    Describe your 9100 Next Generation Remanufactured Treadmill Problem display shows waxer disconected ???
    Dear Sir:
    I will help you inmediately.
    1) Display does not illuminate
    when machine is powered
    on.
    Insufficient power source.
    Plug treadmill into a dedicated amp circuit.
    2) Loose 10 pin connection at
    display console or wax/lift
    control board.
    Check all electrical connections for proper
    attachment.
    3)Damaged main harness wire
    connection.
    4)Replace wire harness.
    Faulty display console or Wax/
    Lift Board.
    Verify if 8VDC is present at P1 pin, 3-4 and
    12VDC at P1 pin 9.
    a)If yes, replace Display Console.
    b) If no, replace Wax/Lift Board. See How To...
    Replace Wax/Lift PCB.
    Use VOM digital (Voltimeter)
    Hoping that you can resolve, if you need some extra help, please reach me.
    blessing.
    E.CUADRA
    MANAGUA, NICARAGUA. C.A.
    I have a life Fitness 9100 that do great walking but if I start running on it, it will automatically shut down to start menu. Is it the wax? or any suggestions?
    the stop switch is bad to check this out start the tread and press around the stop switch on the counsel and see if it shouts down
    1helpful
    I can't reset a fault named "wax empty" and my equipment doesn't work life fitness 9100
    hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
    My treadmill says waxing needs refill maintainance required
    1) Flip the treadmill on its side to expose the bottom 2) remove the two screws holding the rectangular metal wax cover 3) remove the wax cover 4) you should see a bag of wax, replace it with new 5) type in 5-1-2-5-Enter to reset the wax statistics
    2helpful
    I have a life fitness treadmill and put new wax in the blader how do i start the machine and put wax on the belt?
    1helpful
    Refilled with wax how to reset display
    you have to enter maintenance mode, press (CLEAR) and then press the key (PAUSE) there will appear a message that is doing a checkup, then using the keys you move up to find "Maintenance" and press enter Ahi provided with keys look for the option "WAX REFILL" press "ENTER" and ready and be 100% if you have any additional questions here's my e [email protected]
    Top Life Fitness Exercise & Fitness Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Mike Cairns
    Mike Cairns
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
