2004 Dodge Caravan Logo
Posted on Feb 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio CD not working & lights don't flash remote keylock
2004 Dodge Caravan
The remote keylock used to flash van's lights but stopped.
Then a few weeks later, the radio stopped turning on.
This may have occured shortly after I put a phone into the cigarette lighter for charging.
A week later, I put the device again into the cigarette lighter, and the radio started working again. But only for a day.
Then the radio went out permanently.
Fuses all appear good. I took out the IOD fuse for 10 seconds as well, and took out the BCM fuse as well. Nothing seems to correct the issue. Everything else seems to be functioning.
Is this possibly a short or grounding problem?
  • doug419 Mar 14, 2009
    Thanks for your suggestion.
    I removed the battery and it was out of the vehicle for over an hour. It didn't correct the problem. I haven't gone to the dealer yet, but wonder if any other expert would recommend resetting the codes? A guy at work thought maybe I have a grounding problem just hearing the story.
    So, I either take it to a car electical company to see if it's a grounding problem or go to a dealer? What's your recommendation?
Anonymous
Level 2:
  • Expert 115 Answers
  • Posted on Feb 15, 2009
Anonymous
Expert
Level 2:
Answers
115
Questions
0
Helped
78742
Points
403
Sometime the computer in car will shut down a circuit when it sees a problem even if it only occure once. You can try to disconnect the battery for at least 2 min so all sys power off (some have capacitors that mantaine a charge for short time). If a battery disconnect does not clear problem you have go to dealer and have them to clear codes and reset you modules and your preferences
My wipers...lights..radio and horn went out but I can drive the car..what would cause this?
2008 Chrysler Town & Country Intermittent Electrical Failure ...
www.carcomplaints.com/Chrysler/Town_Country/.../intermittent_electric...
The 2008 Chrysler Town & Country has 25 complaints for intermittent ... The horn,lights, wind shield wipers front and back going crazy could not shut off. .... I was Driving down the road and my van went crazy possessed! ... Electrical checks reveal nothing wrong with the electrical system, and there is power to the radio.
2003 Dodge Caravan ES Electrical Problem - Discussion on Topix
www.topix.com > Dodge Grand Caravan
Aug 7, 2011 - my van was running fine, shut it off, went in for half an hour then it would not ... or the electric doors. windows do and brake lights. heater stays on hot and i can only ... My horn wipers,power windows, radio,blower front and back, headlights, do not work. ... Chrysler Readies Next-Generation Town & Country.Missing: 2004
Thread: I lost almost all of my dash lights, instruments, and ...
forum.chryslerminivan.net/.../7261-I-lost-almost-all-of-my-dash-lights-i...
Jan 17, 2008 - 10 posts - ‎6 authors
I have a 2003 Town and Country mini-van and I lost power to all my ... In addition to this my wipers, headlight controls, blinker controls, power door locks, and A/C/heat controls are out as well. The odd thing is that the power windows work, the power sideview mirrors work, the radio and ceiling lights also work.
I have 2004 dodge caravan security light flashing
The cars security system is armed. Is the remote working?Or you can try using the drivers side door lock with the key and unlock the door with the key that will turn alarm off it the remote is not working.
1helpful
2005 Dodge Grand Caravan Electrical cluster problems
I am having the same problem. Are you losing power at all when this happens?
6helpful
Keyless remote stopped working, I replaced battery
The 1997 to 2003 Dodge Caravan and Grand Caravan use a standard key and remote setup with a separate remote fob. However, the 2004 to 2009 Dodge Caravan and Grand Caravan use a combination key and remote on one device. To program a new keyless entry remote for the 1997 to 2003 Dodge Caravan, you must have at least one functional remote, which is required to enter synchronization mode. To program the combination key for the 2004 to 2009 Dodge Caravan, you must have two functional combination keys. If you do not, you'll need to see an authorized Dodge dealer for keyless entry programming assistance.
2004 to 2009 Caravan Programming Instructions
  1. Insert one of your working combination keys into the ignition. Turn it to "On"; leave it in this position for about 10 seconds but no longer than 15 seconds. Turn it to "Off" and remove it.
  2. Insert your second working combination key into the ignition within 15 seconds of removing the previous key. Turn it to "On". After 10 seconds, you'll hear a chime and the "Theft" light will begin to flash, entering synchronization mode. Turn the key to "Off" and remove it.
  3. Insert the combination key you want to program. Turn it to "On." After 10 seconds, you'll hear a chime; then the "Theft" light will turn off. When the light turns off, the combination key--including the key and the remote--is programmed.
  4. Repeat Step Three for each combination key you want to program. A total of eight can be programmed.
Hope this help (remember comment and rated).
5helpful
2004 Dodge Caravan won't start...just a clicking noise...
Check the battery first. Just because the lights are on doesn't mean it has enough power to start the van. If you or the van has a volt meter, the battery should read at least 13-14 volts to be good. If the battery is good then the alternator is good and we move on to the starter solenoid. I'm sure it's one of these. Do the lights go off or very dim when you turn the key? If so then battery.
3helpful
Dodge Caravan Stalls, won't turn over
i have the same van (2003), same problems, the deler just replace my PCM cost me $950 van works fine untill now.
2002 Dodge Caravan se radio problem
Does it have RADIO Controls on Steering Wheel? If so does the Air bag light EVER come on While Driving down the road. If no to these Questions.
I dont like at all being the Bearer of BAD news
I am Not Exactly A "RADIO" Expert But I have seen this Before and My Repair for it was Replacement.It is My Thought and Thery that somehow the MEMORY Cuircit gets Burned out adn in turn the On Off Cuircit is also Effected by this, Hoping this is of Good Help to you., RejakWilson
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
