2009 Mercedes-Benz GL 500 Logo
A
Anonymous Posted on Sep 10, 2017
I am looking to buy a Mercedes GL 500, model 2009. One of checks a friend of mine does before buying a second hand car is to start the engine and then open the hood and remove the oil cap, according to him if oil bubble out then it is not a good sign. When we did that with the GL I was interested in, oil bubbled out. Is oil bubbling out any indicator of engine problems?
Iulian Spuze
Level 2:
Habit-Forming:
New Friend:
  • Expert 81 Answers
  • Posted on Sep 10, 2017
Iulian Spuze
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
81
Questions
0
Helped
22240
Points
251
Oil bubbles when engine run and remove oil cap is normal. Abnormal is some strange noise from engine, short and quick lifting when pressing shock absorbers, traces of rust, etc
john h
Level 3:
Top Expert:
  • Mercedes-Benz Master 29,494 Answers
john h
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7560947
Points
193449
Oil bubbles ? oil splashes under valve covers across the valve train opening the valve cap may get oil splash-- but oil bubbles oil may foam a bit from being old or if coolant got in it and wouldnt bubble out of cap but bubbles --- and oil splash is normal when opening oil cap with vehicle running
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 28, 2009
SOURCE: engine oil for Mercedes C 200 kompressor 2005 model classic
Product-advies voor
Personenwagens,Jaargang: 1998 >
Mercedes-Benz, C-Klasse (2000 - )
Component Product
Motor 271.942
Inhoud: Smeermiddel inhoud 5,5 liter Inhoud filter 0,4 liter
Eurol Synergy OW-40
Eurol Qptence 5W-30
Eurol Fluence 5W-30
Eurol Super Lite 5W-30
Eurol Super Lite 5W-40
You have a board -computer,which tell you when you have to change oil,aproxem.30.000km(or 2 years)
Anonymous
  • 43 Answers
  • Posted on Apr 01, 2009
SOURCE: Open Hood warning, and wiper blades.
There is a switch on your hood latch. They get damaged sometimes when the hood opens and closes. look down on the latch and you will see the sensor with an electrical plug. There are two 10mm bolts holding the latch in. remove them and the sensor is in the latch.
Anonymous
  • 710 Answers
  • Posted on May 02, 2009
SOURCE: engine oil light came on, on my mercedes ML 350, 2006 model.
IT MEANS THAT YOUR OIL LEVEL IS VERY LOW AND NEEDS TO BE FILLED. CHECK THE OIL LEVEL WITH THE DIPSTICK IF EQUIPPED. IF NOT, THEN ADD 1 OR 2 QUARTS OF OIL TO SEE IF THE OIL LIGHT GOES OFF. IT MAY TAKE SYNTHETIC OIL SO DON'T PUT CONVENTIONAL OIL IN IT IF YOU SEE A MOBIL 1 SYNTHETIC OIL RECOMMENDATION STICKER UNDER THE HOOD. IF YOU ARE UNSURE THEN BRING IT TO A QUALIFIED TECHNICIAN A.S.A.P.. HOPE THIS HELPS. GOOD LUCK.
Anonymous
  • 408 Answers
  • Posted on May 22, 2009
SOURCE: C220 fuel pump
hello,good day,seems you have a leaking problem,check your all clamp,seal ring, or you have a internal leak,maybe the check valve in your fuel pump is leaking,or some fuel system have fuel accumulator,maybe the check valve is leaking,ty
Anonymous
  • 99 Answers
  • Posted on Aug 03, 2009
SOURCE: Engine Coolant Temperature Light came on
whats happening is your a/c is putting an extra load on the engine. it happens with any car. that generates extra heat. it is possible that you need your coolant topped off, but chances are that your car would have overheated before if that were the case. what i would recommend is to first check to see if the coolant level is good. if it is, then get the car up to operating temperature and check to see if the cooling fans on your radiator are working. if not, it may be a bad fan, or just a fuse or relay. if that doesnt solve your problem, have the thermostat changed out for a new one. theyre pretty inexpensive. second, if you or someone you know has the know-how, remove the radiator, plug the fittings for the transmission cooler if it has any, and use a power washer to clean the radiator out. sometimes dirt can accumilate there over time and it wont let the heat dissipate properly. a coolant flush wont be bad for your car, but probably wont make your problem go away.
2010 C300 4Matic - my handle and lock have been broken on my glove box. Can I buy the handle and new cylinder or do I have to buy a whole new glove box door?
Buy second hand mercedes have a habbit of charging for a whole door instead of just yhe part you need then theres colour matching faid ect a good second hand one should cost around 20 pound in the colour you need
Mercedes 350 GL Bluetec What is the best chip for this car - I am buying a new one next week -
Hi Dr Sethi,
I'm not sure where you are located, but the below links are from companies in Europe, they have plug-in chip units that increase power and torque for Mercedes 350GL Bluetec:
Chip Express - http://www.chipexpress.com/products/1292/
Race Chip - http://www.racechip.com/chiptuning/mercedes/gl-class/x164/gl350-bluetec-starting-2009-155kw/index.php
Where is the engine number for Mercedes E240, 2002 model, located?
front of cylinder block right hand side if my memory is correct or look in the alldata book ,mine are in the workshop or i would look now for you
2answers
How do you reset maintenance indicator on a 2006 cls 500 mercedes
There is only 2 ways.....1 take it in to a qualified repair shop that has the diagnostics tool or buy it yourself from Autozone or NAPA. ETC. Hope this is the info you need. You might be able to find a friend that has one. They cost anywhere from 200-300 dollars.
Used Mercedes Benz GL450 2007
over 80% of mercedes ever made are still on the road in use,only volvo can beat this fact with over 90%.
keep it serviced at 10k intervals,and it should last 30 plus years.
bodywork is galvanised,so look after paintwork(1 dent/scratch will knock over $1000 off the price...)only buy if full leather and keep it fed.
The carb. cant work uniform...i need schem of fitting of it
hello,good day,you have a stromberg carburetor,with engine number 102.921 or 938,,if you always dismantle your carb. there is a tendency that your carb. have air leaking problem,try to renew or buy a overhauling kit for your carb.or if you have access in second hand carb. buy it,,ty
My 1998 VW Jetta GL - Ignition Switch
It could just be out of adjustment. I recommend going to a dealership for the part. The VIN number should identify your car specs exactly to avoid getting the wrong part
How much cost to replace a mercedes-benz engine
in australia an engine is worth aprox $ 3000.00 second hand
Thinking of buying this car
Got my GL 320 CDI in Jan. Drove it to Amelia Island, FL this Easter from Michigan and had 2500 miles at the time. 500 miles into the trip, 2 problems showed up. 1. low oil level warning indicator went on a total of 6-7 times for the round trip. I suspect the dealer I got it from did not hand over the veh to me with a full tank of oil. I had to put in 2 quarts on the way to FL. Had it checked at a MB dealer in JAX and they said there was no leak. The low oil level warning came on again on our trip back to MI but the oil levels were full. 2. The worst problem was that the shock absorber on my right rear wheel was defective. Noticed the problem on the way to FL when I stopped to check the oil level. Watch out for a metal-to-metal grinding noise. It is not the brakes! We had a fully loaded vehicle with 4 occupants and a Thule luggage carrier on top. I didn't know the shock absorber was the problem until I had the Jacksonville dealer take a look at it. Found out there are over 70+ SA's on backorder across the US. Tells me there may be a defective shock absorber problem. Since I needed a new one right away to make the return trip to MI, the dealer pulled a GL off their lot and transferred the SA to my vehicle. Thank God! Drove fine the rest of the way ty that may stress the front end bushings, etc.
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
