Van chugs/stutters intermittently at a consistent high speed, fuel gauge vibrates, sometimes (rarely) it turns over and acts like it wants to start but won't. Replaced, fuel pump, fuel filter, ign coil, coil wire but no change.
SOURCE: 1997 GMC Savana 5.7 L conversion van. Cranks but wont start
Fuse? Check crank position sensor.
SOURCE: low fuel pressure 1996 savana 5.7 V8 central sfi
The only thing left in this system is the fuel pressure regulator. You need to check pressure before the regulator and after the regulator if there is the problem then you need to replace it. I hope this helps. Don't forget to rate my answer.
SOURCE: 95 gmc safari problems
yes delivers the fuel bat is not enaf pressure replase fue pomp end you be ruaning agein
SOURCE: my 1999 gmc savana van turns over but does not
could be a bad fuel pump, or fuel pump relay. they are having problems(a lot) with the ethanol in the gas on GM products.Fuel pumps sales are through the roof at parts house on GM's. Have a pressure check on your fuel system. That is probably it. Add a can of Seafoam to your fuel every 3000 miles to alleviate this problem.
SOURCE: stuttering on acceleration and/or at highway speed
it also could be a plugged catalytic converter. hope this helps
