Cars & Trucks Logo
Jashua Mose Posted on Sep 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Magnavox 32mf3018 digital audio output not outputting a signal to my amplified surround sound speakers
I hooked it up, no sound. Even if I go through the sound setting and change them. still nothing. yet if I hook up my speakers to my Samsung BD/DVD players audio outputs they work. Yet I play video game systems through my tv and would like to get the surround sound for them too, without having to jury rig all the wiring to my speakers amp.
Marvin
Level 3:
Top Expert:
  • Cars & Trucks Master 85,242 Answers
  • Posted on Sep 18, 2012
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29060828
Points
266281
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems.
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Dec 30, 2008
SOURCE: Anyway to bypass my Bose Amplifier
not too sure what you are trying to do but just buy a aftermarket deck..for example for 100 bucks jvc has a nice deck with remote that plays mp3 and even has a jack right on the faceplate for a mp3 player.then throw your subs in the trunk hook up the amp and bingo banging beat.if u have the aruroa with the battery under the back seat its even easier
Anonymous
  • 6966 Answers
  • Posted on Feb 18, 2009
SOURCE: Amplifier hook up
Hi and welcome to FixYa,
As you have planned, the "product from scosche" would convert the speaker outputs to line level suitable for the Line level input of the amplifier. The RCA (red & white) would provide the connections. Of interest would be the following wires of the Neon:
  • Pink/Light Blue - always on B+12 (connected directly to the battery)
  • Red/White - IGN switch controlled ACC +12
  • Black - GROUND
  • Dark Green - left front +
  • Brown/Red - left front -
  • Violet - right front +
  • Dark Blue/Red - right front -
  • Brown/Yellow - left rear +
  • Brown/Light Blue - left rear -
  • Dark Blue/White - right rear +
  • Dark Blue/Orange - right rear -
You need to decide which speaker pair you would want to tap/convert to RCA type, front or rear.
Incidentally, the stock Neon stereo does not have a trigger wire to activate the external amplifier. This being so, a separate switched + 12 must be wired to trigger the external amp. This is separate from the always on B+12 of the amp.
Good luck and thank you for using FixYa.
Anonymous
  • 31 Answers
  • Posted on Mar 08, 2009
SOURCE: I want to hook up 6x9's in my back window of my 01 LS
yes splice it to the rear door speakers with the proper kit
Anonymous
  • 134 Answers
  • Posted on Mar 15, 2009
SOURCE: how to hook up wii to surround sound
You need to connect your amplifier to your TV, (Video Out of Amp to video In of TV), then select the input where you connected your WII in amp.
Or you could just connect the yellow plug to the TV directly, and the white and red plug to your amplifier.
A note thou, Red and White will not give "True" surround sound as it has only 2 channels, you need to connect a digital input to the amp to get true surround.
Let me know what happens
Alex
www.CAS411.com
Anonymous
  • 82 Answers
  • Posted on May 10, 2009
SOURCE: 2005 yukon denali xl suddenly has no audio sound.
What is the current system you are using the factory one or aftermarket? You have an amp in the center console now?
2answers
I have an 04 Saturn Vue. My radio turns has power, CD player works but I cannot get any sound. Other day when I was driving the speakers got all staticky and then sound went out. I check the 3 fuses and...
What system does it have ? Base or up level ,does it have a amp ? Do you know what a RPO code is ? Without testing no one could say for sure what the issue is . First off would need to know what system we are dealing with .
RPO Options
The entertainment system on this vehicle is configured with either a base or uplevel audio system. Both the base and uplevel audio systems contain a radio, antenna, and speakers.
The following shows the Enteratinment RPOs that are available for this vehicle:
• (UM7) AM/FM Stereo
• (U1C) AM/FM Stereo CD
• (US8) AM/FM Stereo, CD, MP3, RDS, EQ
• (US9) AM/FM Stereo, 6-Disc CD, MP3, RDS, EQ
• (UXQ4) Base Four Speaker
• (U79) Uplevel Four Speaker
• (WBM) Premium Audio
• (U2K) Digital Radio
Circuit Operation
Radio Power: The main radio power is supplied by the 10A RADIO (BATT1) fuse in the body control module (BCM). Radio switch-on power, 12 volts in ACC, RUN or RAP, is supplied by the 10A RADIO (ACC.) in the BCM.
Radio Grounds: The main radio ground provides a ground for the radio circuits. An additional braided ground strap provides a shielding radio case ground to reduce EMI noise. Both grounds are connected together inside the radio.
Radio Speaker Outputs: At zero volume, the plus (+) and minus (-) speaker outputs are both approximately 5-6 volts, measured to vehicle ground. If a plus or minus for any speaker output is shorted to ground or voltage, the radio circuitry will turn OFF all 4 speaker outputs for component protection. Above zero volume, the plus and minus change to create a voltage difference between each other, to drive the voice coil of the speaker.
Radio Park Lamp Input: The radio park lamp input allows the radio to sense when the vehicle parking lamps are ON. When the parking lamps are ON, this circuit goes to battery voltage, and the radio display back-lighting switches from full bright to the brightness level determined by the I/P illumination input.
Radio I/P Illumination Input: A pulse width modulated (PWM) voltage for instrument panel (I/P) illumination is provided to the radio I/P illumination input. The Radio uses this input to directly illuminate the radio buttons and adjust the radio display back-lighting when the park lamp input is ON.
Amplifier Power: The main amplifier power is provided by the 20A PREM AUDIO fuse in the instrument panel fuse block..
Amplifier Radio Speaker Inputs (WBM only): The radio speaker outputs, at a reduced output level for amplified systems, are the amplifier inputs. The amplifier boosts these inputs and outputs them to the vehicle speakers. Speaker plus and minus circuits from the radio change to create a voltage difference between each other. If one speaker plus or minus is open between the radio and the amplifier, the input to the amplifier is approximately half because only one of the circuits is changing. The speaker for that channel then operates at approximately only half the normal volume.
Amplifier Speaker Outputs (WBM only): At zero volume, the plus (+) and minus (-) speaker outputs are both approximately 5-6 volts, measured to vehicle ground. If a plus or minus for any speaker output is shorted to ground or voltage, the amplifier circuitry will turn OFF either the front outputs or rear outputs for component protection. Above zero volume, the plus and minus change to create a voltage difference between each other, to drive the voice coil of the speaker.
Amplifier Radio-On (WBM only): When the radio is ON, this circuit is pulled to 12 volts by the radio. The amplifier switches ON when this circuit is 12 volts and switches OFF when this signal is 0 volts.
Remote Radio Audio Signal Inputs (UE1 only): Audio output from the OnStar® communications module connects to the remote audio signal inputs of the radio. When the cellular telephone mute signal goes to 0 volts, the radio over-rides any other audio signal and uses these inputs as the source for output to the speakers.
Cellular Telephone Mute (UE1 only): The OnStar® communications module uses the cellular telephone mute signal circuit to over-ride the radio for OnStar® communication. When cellular telephone mute is not active, this circuit is held at 2 volts by the radio. When the cellular telephone mute signal is pulled to ground, the radio over-rides any other audio signal and uses the remote audio signals as the source for output to the speakers. If the radio was OFF when this circuit is pulled low, the radio will turn ON. Additionally, the radio fades the speakers to full front, adjusts the volume to an initial audible level, and sets an AutoTone designed for optimal use with OnStar®. When the mute signal is no longer pulled to ground, the radio returns to the mode it was in previously.
Hooking up a professional or factory scan tool that can read radio codes would be one of the first test's to do .
DTC B1025, B1035, B1045, or B1055 (w/out RPO WBM)
DTC B1025, B1035, B1045, or B1055 (w/ RPO WBM)
DTC B1030, B1040, B1050, or B1060 (w/ out RPO WBM)
DTC B1030, B1040, B1050, or B1060 (w/ RPO WBM)
DTC B1259
The following conditions are present for 250 ms or longer:
B1025 - B1055 01
One of the speaker positive output circuits is shorted to battery.
B1025 - B1055 02
The speaker positive output circuit is shorted to ground.
B1025 - B1055 04
The speaker positive output circuit is open.
Your best bet , take it to a qualified repair shop .
I have 2005 chevy silverado 2500hd crewcab 6.6 diesel 4x4 stereo speakers some days are normal volume n some only woofer spreaker.other problem windshield wiper washer doesnt work
Which of these does your truck have ?
The Entertainment System on this vehicle is configured with a radio, antenna, and speakers.
The following list shows the radios available for this vehicle:
• Radio (UM7) - AM/FM with Cassette
• Radio (UB0) - AM/FM with CD
• Radio (UB1) - AM/FM, Cassette and CD
• Radio (UC6) - AM/FM, Integral Multi Disc CD Changer
Audio Amplifier
The audio amplifier is standard on some vehicle lines but is optional on most. The radio supplies low level audio signals to the audio amplifier in order to boost the signal sent to the speakers. The class 2 signal circuit allows the radio to recognize that an amplifier is present. Once the radio detects an audio amplifier, it will output low level audio signals. The audio amplifier is turned on when it receives a message via the class 2 serial data circuit indicating that the radio is on.
Digital Radio Receiver
The radio communicates with the digital radio receiver via the class 2 communications circuit. The digital radio receiver sends low level audio signals to the audio amplifier.
Steering Wheel Controls
Some audio functions are available using the steering wheel controls. The steering wheel controls consist of multiple momentary contact switches that connect a series of resistors. When a steering wheel control button is pressed, a specific resistance value is noted by the body control module (BCM). This results in a generated voltage, unique to the particular button. The BCM alerts the radio that the button has been pressed, and the radio responds, just as if the corresponding radio front panel button had been pressed.
Amplifier
The amplifier in early build vehicles is a class 2 device that communicates with the scan tool on the Class 2 bus. The Class 2 amplifier will set a U100 in the radio if there is a communication problem. The late build vehicles have a NON-Class 2 amplifier that does not communicate over the Class 2 bus and therefore the NON-Class 2 amplifier will not set codes. Both amplifiers have similar operating characteristics, therefore, there are not separate diagnostics for the NON-Class 2 amplifier.
Circuit Description
When the radio is powered up, the radio supplies low level audio signals to the speakers. If the vehicle is equipped with an audio amplifier, the amplifier will boost the signal sent to the speakers. The radio tests the speaker output circuits for a short to voltage or ground.
DTC Descriptors
This diagnostic procedure supports the following DTCs:
• DTC B1025 Audio Output 1 (Left Front) Circuit
• DTC B1035 Audio Output 2 (Right Front) Circuit
• DTC B1045 Audio Output 3 (Left Rear) Circuit
• DTC B1055 Audio Output 4 (Right Rear) Circuit
Reduced Volume - One or More Speakers
Step
Action
Yes
No
Schematic Reference: Radio/Audio System Schematics
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
Turn ON the ignition, with the engine OFF.
Turn ON the radio.
Adjust the radio balance and fade controls to each speaker.
Do all of the speakers operate properly?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
Turn the ignition ON, with the engine OFF.
Adjust the volume level.
Test the appropriate speaker output circuits of the radio for A/C voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did the A/C voltage fluctuate with the audio output?
Go to Step 4
Go to Step 8
Turn OFF the ignition
Disconnect the radio.
Test the appropriate speaker output circuits of the radio for high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 9
Go to Step 5
5
Inspect for poor connections at the harness connector of the radio. Refer to Testing for Intermittent Conditions and Poor Connections in Wiring Systems.
Go to Step 9
Go to Step 6
6
Inspect for poor connections at the harness connector of the appropriate speaker. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 9
Go to Step 7
7
Replace the speaker. Refer to Speaker Replacement Reference .
Did you complete the replacement?
Go to Step 9
8
Replace the radio. Refer to Control Module References in Computer/Integrating Systems for replacement, setup, and programming.
Go to Step 9
9
Operate the system in order to verify the repair.
Did you correct the condition?
Having trouble with all my speakers except my twitters in a 2007 Saturn Outlook...what do I start with? Fuses are good
Speakers get power from the amp if your system has one or from the radio , if the tweeters work it's not a fuse problem . You like listen to your stereo loud . Blew a channel in the radio or amp ?
Take it and have it checked for DTC'S - diagnostic trouble codes
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier (if equipped) have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5 V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3 V AC and slightly higher.
Do you know how to do DC voltage testing ?
Without Amplifier without UK6
Ignition OFF, disconnect the harness connector at the appropriate speaker.
Radio ON, test for 5.0-7.5 V between the signal circuit terminal A and ground.
? If less than the specified range, test the signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the radio.
? If greater than the specified range, test the signal circuit for a short to voltage. If the circuit tests normal, replace the radio.
Test for 5.0-7.5 V between the signal circuit terminal B and ground.
If all circuits test normal, replace the speaker.
How do I work out why there is no sound at all from one of my speakers. I have switched them and it is definitely the speaker
After confirming speaker is not getting the audio, need to work toward the audio output. Your next stop will be the audio output from the power amplifier (if there is one), or if the audio is coming out of the car radio. If audio is at the source output (or amp out), you have a broken wire between the source and the speaker. Bypass this wire to test.
I have a 2010 cobalt lt. Today both my feont speakers quit working. And now my turn signals make no noise. Or the door chime or the seatbelt indicator does not work. What causes this and how do I fix it?...
The chimes an turn signal noise come out driver door speaker . Both front speakers not working could be a blown circuit fuse inside the radio or just blown front speaker channel . Your best bet , take it to a GM dealer or someother qualified repair shop . You have no idea of the complexity of this . The radio can set DTC'S - diagnostic trouble codes , believe it or not !
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3V AC and slightly higher.
DTC B1287 01: Amplifier Control Signal Circuit Short to Battery
DTC B1287 02: Amplifier Control Signal Circuit Short to Ground
DTC B1287 04: Amplifier Control Signal Circuit Open
The radio provides a remote amplifier mute output circuit to control overall muting of the remote amplifier. The amplifier receives pulse width modulated (PWM) signals on the control circuit at varying duty cycle percentages for controlling muted and unmuted functions of the amplifier. Circuitry internal to the radio monitors the remote amplifier mute circuit for faults and sets the appropriate DTC when faults are detected.
Need help putting in stereo for a 1998 toyota avalon xls
hook speaker wires to the amplifier output, can't use from the radio wires because they used a not smart design using one wire output from radio to amplifier, the amplifier output is connected to your soeakers, a simple check, use 1.5 battery to speaker and check the speaket, should move, or hook to some cd player output, easier that way
Installed a Sony Xplode into a 99 Blazer and everything on the radio works but will not play through the speakers
The Bose system is complex - it has an amplifier separate from the Bose compatible radio. This amplifier takes low level audio signals from the radio, not full driver outputs from a replacement radio, and by trying to use the replacement radio you may have blown the amplifier. If that is the case, you may not be able to go back to the original radio.
The only option you may have with the replacement will be to find the Bose amplifier and bypass the connections to feed the replacement radio outputs directly to the speakers. This may not be as simple as it sounds, as distribution to the various speakers comes from the amplifier, not the radio, and the wiring from the amplifier to the radio may not have all the wires you need. Before going on, you had better get a wiring diagram for the Bose system (service manual or Alldatadiy.com).
5helpful
2answers
I need to know the wiring diagram delco radio model output 16141222
1992 Pontiac Grand Am Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck and merry xmass
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
