I have recently bought a bmw 318ci 2005 and is all really good, past m.o.t and machanic said it is really nice and in brilliant condition. I have just serviced it and problem is still there? When I pull away I sometimes get a jerking feel like its holding back? It only happens when excellerating whilst pulling away? Any help welcome! Cheers!
SOURCE: 2002 BMW 325 Air Condition Problem
It needs a new fan control. $80 online and 20min. labor. I just replaced mine in the same car.
SOURCE: bmw 323i loss off power cutting out
have the catalytic converter checked out...if they clog it will make the car run wrong and cut out and die
SOURCE: bmw 116i service, when?
Tere should be an automatic service light that comes on when you turn the key. How many miles are on the clock and when was the last service?
SOURCE: i have a bmw 318ci 2002 model which keeps
Hey, sounds like a vacum leak - common on those engines. when engine is on idle open boonet and lissten out for any whoosing noises near the rear of engine. There is a breather there that can be changed ( black round ) or check the pipes that connect to it coming from rocker cover for damage.
SOURCE: BMW 318ci 2003 Blue Smoke When Engine is Warm
you definitley seem to be getting oil in your combustiion chamber, pull your spark plugs and see if they are coverd in oil. if so your valve seals are bad, if not your piston rings are bad. As far as the kncking noise its hard to tell though a description, id have to hear it, but ill go out on a limb and say its in relation to the leak it could be a piston or valve knock. The garage heard the noise, ididnt so i hope i could help.
