Cars & Trucks Logo
Anonymous Posted on Sep 04, 2012
My benz won't stay running unless I hold the gas down constantly
Anonymous
Level 3:
  • Master 747 Answers
  • Posted on Sep 04, 2012
Anonymous
Master
Level 3:
Answers
747
Questions
0
Helped
260340
Points
2321
Sounds like a fuel pressure issue check fuel filter lines& linkage
  • Anonymous Sep 05, 2012
    thanks! I'll have that checked. it runs fine, it just that when I stop for a light, when I step back on the gas it bogs down & tries to stall.unless I hold 1 foot on the gas.
2003 Dodge Durango (5.9L V8) won't stay running unless you keep your foot on the gas.
Check temp sensor and TPS, throttle positioning sensor.The power control module,"pcm.is a possible thought.Just check all connections. It is always a good idea to spray WD 40 or equivalent in the connections.
1helpful
2answers
I have a 97 dodge stratus. It won't start. Tried
Make sure it's getting fuel. Try using some ether or starting fluid. If it rumbles to life but doesn't stay running then there's a problem with the fuel delivery system. i.e.... Fuel pump, clogged filter, pressure regulator.... If the ether doesn't change the results you are getting now then it's a fire or sensor problem. Ignition coil, relays, sensors not signaling, PCM... I wish you luck. Let us know how it turns out
98 Expedition..5.4L 4WD..coded bank 1 bank 2....O2 sensors..LEAN....replaced both..no change..still same codes..now it won't stay running. Tried to code again..won't run long enough to get a c
all code readers will retrieve information stored while in the on position --doesnt need to be running ---when you rehook up scanner either resubmit or edit request with codes
My jeep won't start unless I give it gas. It used
Did you clean the throttle body and plate of any carbon ?
1helpful
My 2001 ford crown victoria won't stay running unless i hold my foot on the gas
A few different things could be going on here. Some things to check: possible vacuum leak, TPS (throttle position sensor), IAC (idle air control valve). I would check these first. Is the ck engine light on? If it is, take it to your local O'Rielly's or Auto Zone, they will scan it for free. Hope this helps, TJ
2answers
2000 Ford Crown Victoria
when you hold the accelerator does the vehicle stay running? if so the problem is in ithe IAC idle air control motor, take a small screw driver and using the handle tap the iac motor and usualy the motor will kick in and the vehicle will run fine then if the problem is rectified replace the IAC
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
