Absolutely, simply slide the plastic strip back into the battery slot and between the batteries.
The outer casing of the balls is made from non-toxic, rigid, plastic. It is tough enough to discourage most chewing dogs.
The babble balls are guaranteed to be free of defects and most companies will give you a new ball I case it has any defect. The babble balls have no warranty over chewing damage, abuse or warn out batteries.
You should use a clean damp cloth with and gently wash the dirt and saliva off the ball's surface. Don't submerse the ball as it will damage the electronic components of the ball.
The babble ball appeal most dogs that like to play and run. Some timid dogs may be initially cautious nut curiosity usually wins over quickly.
The babble balls contain electronic components and are intended as an indoor toy. The ball won't be damaged by chewing or hitting walls but it is not designed to be hit with baseball bats or tennis rackets.
Depending on your dog play habits it will last more or less. For instance if your dog causes the ball to make 100 sounds per day, it should last for approximately 4 to 6 months.
The Small Babble Ball is intended for the tiny breeds up to 10 pounds. The Medium Babble Ball is for dogs 12 to 25 pounds and the Large Babble Ball is for the large breeds above 25 pounds.
The babble ball combines features that every dog loves, ball shaped toys and noisy toys. The more your dog plays with the ball the more he will like it.
