There are several brand and varieties of gravel to choose
from. I would be more than happy to post
some of the more preferred brands here for you; however the choice is not so
simple. Make sure you know what kind of
gravel you need for the type of tank you have.
http://www.petsmart.com/product/index.jsp?productId=3577442
http://www.petco.com/product/112362/CaribSea-Instant-Aquarium-Crystal-River-Gravel.aspx
It is most likely that the gravel you are using contains
calcium and magnesium. This will
ultimately cause the pH level in your tank to rise. You should use an inert gravel such as Swell
Harlequin Gravel.
http://www.swelluk.com/aquarium/substrate-1695/gravel-1829/swell-harlequin-gravel-blue-376469.html
Most gravel sold today are pre-washed although gravel can accumulate grit in transit as the grains rub together therefore it is advise to wash them.
The aquarium gravel creates a pleasant environment and makes the aquarium look so much nicer than with a bare tank floor.
The aquarium gravel creates a pleasant habitat for fish. In this comfortable environment the fish will experience less stress and will be much healthier.
Yes, if there is no gravel in your aquarium, there are not bacteria colonies because they can only thrive in gravel environment, therefor you need to replace the water more often.
The gravel provides a home for beneficial bacteria which help dispose waste products in your aquarium, and the useful colonies of bacteria can only thrive in gravel.
Cloudy water is
often a sign that you did not wash your gravel thoroughly. If you did, you may
have a bacterial bloom. For crystal clear water, an ultraviolet sterilizer is
the best permanent cure.
