SOURCE: I have a Timex Ironman Triathlon Speed + Distance...
The Timex Ironman manual and website says to take the watch to a repair facility. Nope! Do it yourself!
How to replace the battery in a Timex Ironman watch:
This is easier if you remove one of the rubbery wrist bands.
1. Take note of the position of the metal back cover. You'll need to reinstall it exactly as you see it in order to hear the alarm.
2. Remove the four screws that hold the metal back cover, and pry off the cover.
3. There is a round metal clip that holds the battery in place, covered with a transparent plastic cover which likely says, "Unlatch to remove battery". Within the center of each clip, there's a small opening just large enough for a straight pin to be inserted. A jewelers screwdrive won't work - use a straight pin. Insert a straight pin into the tiny opening at the edge of the clip, and wiggle it. The clip should release. You'll only need to unlatch one side of the battery retaining ring.
4. Gently pry up the batter retaining clip, then pry up the battery. Insert new battery.
5. Replace the clip.
6. Insert a flat blade screwdriver into a slot which has two "electrodes" or pins - they need to be shorted with the screwdriver to reset the watch. Just touch the screwdriver blade across the two pins to short it.
7. Reinstall the back cover but be sure to position the cover so the alarm sounding place ( a small disc attached to the inside back cover) will reside over the sounding spring.
8. Insert screws.
Dave
SOURCE: How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
SOURCE: need setting instructions for date,alarm,etc on my timex expedition
http://assets.timex.com/manuals/index.html
Here is the link for all Timex watches and the appropriate manuals.
This should provide you with the information you require, if you have an issue not covered there I will try to find you more specific information.
SOURCE: need a glass for my timex expedition watch. What
No problem with it. Any watch repair shop will order exact size glass for your watch and will fit it. Fitting is easy if you have special glass fitting press. No way to replace watch glass without this tool. Visit your nearest watch repair shop and ask for new glass. Rate me,plz.
SOURCE: REMOVE BACK COVER
If caseback is without grooves, it is snap on caseback and you have to insert openers blade under the lip and pry up. Lip is the tiny gap between the case and caseback.
If you have groves in caseback, it is screwdown caseback and you will need special opening tool. Insert the blades in to the grooves and unscrew the caseback.
You can find this tool on eBay.
Rate, please.
