SOURCE: No power to DVD combo player. VCR OK.
The power circuit for the DVD and the vcr are separate look for a open diode and transistor in the circuit that supply the DVD.GOOD LUCK.
SOURCE: cannot record thru line 1
If you could but now you cannot then this is a circuit break down- although check your set up , but I feel it is the machine beginning to die
SOURCE: toshiba dvd Video player & vcr SD-V396SU2
Thanks. We have replaced the unit with a JVC but will give the SP/SLP a try just to see.
Anoyed
SOURCE: VCR Play Back is OK, but Recording produces Blue Screen on playback
If the heads are TOO dirty, a head cleaner will not help. If you are cinfident enough to open up the recorder, then they can be cleaned manually.
Disconnect the VCR from the mains.
Remove the screews from the side and back (if applicable) of the lid.
Remove the lid.
Look at the large drum (set at a slight angle) If you gently rotate the drum you will see 2 or 4 small sensors set into the drum.
Tear of a clean piece of A4 paper about 1inch square.
Hold between thumb and first finger and rub the centre of the paper against each sensor in turn. Make sure the edge of the paper does not catch the sensor.
After each sensor check the paper for dirt (black marks) and change paper if need be.
Try a recording / playback.
Repeat if necessary.
SOURCE: GoVideo Dual Deck VCR Model#GV6015with one touch copy
It seems to be fixed. I ran a new tape through the machne as suggested. To be sure, I also used a VHS head cleaning cassette.Works fine, now. Thanks
