Radio Communications Logo
A
Anonymous Posted on Jun 21, 2012
Is there a mod to stop the magnum 257 hp radio from loosing its memory when i dont drive my car for a day?
Sometimes it looses its channel memories if not on power sorce for 12 hours
5 Related Answers
Mechanic688
Mechanic688
  • 204 Answers
  • Posted on Mar 10, 2008
SOURCE: magnum 257 off freq
Colin, here is all the tech info on alignments that your looking for,,,go here;
http://www.cbtricks.com/radios/rflimited/magnum_257/index.htm
Hope this gets you on the right track,, let us know.
Mechanic
Anonymous
  • Posted on Feb 07, 2009
SOURCE: magnum 257 it will not transmit on lsb or usb it will on am and f
With SSB you have to put audio on the carrier you cant just key the microphone and expect it to output a signal unless you talk into the microphone at the same time this is how SSB works.
So if you talk and the meter starts to move then its ok, if you talk or whistle and nothing moves then the circuit on the SSB side of the unit is faulty.
Anonymous
  • 5158 Answers
  • Posted on Mar 24, 2009
SOURCE: My Magnum 257 10 Meter radio will not transmit in any mode.
try this page
Anonymous
  • 219 Answers
  • Posted on May 01, 2010
SOURCE: The Magnum 80watt 257
go to cb tricks .com
Ernest Taylor
  • 67 Answers
  • Posted on Feb 27, 2011
SOURCE: any body there got a service manuel to magnum 257
Here you go! http://www.cbtricks.com/radios/rflimited/index.htm
I have a yellow face magnum 257 I want to mod it for thge 11 meter band also can any one help?
Hi timothy, my name is John. Welcome to FixYa. Are you willing to do this your-self?
Magnum 257HP ,Poor TX audio , tried several mics ,SSB ALC , Bias no effect . Did not align TX lower stages . AM , FM are perfect , all RF power outputs perfect , looks good on scope with generator but...
That mod that magnum does really ups the sensitivity. so much thats is too much. If that model has a switch for the compressor turn it off. It will help 100% and make it sound decent not twangy and over modulated. Just the design of these newer exports are not like the old ones.
I have a Mod 75-830 installed in a BMW motorcycle. Each time the unit is powered down, it goes back to ch 9. is there a way for the radio to remain on a given channel?
The unit needs constant voltage to keep channel memory. So if you have it wired to accessory, every time you turn it off, it looses memory. You need to wire it to constant voltage, and turn it on/off manually.
I fogot how to put my converted 257 magnum into the lower channels and to have it read freq and channel
http://www.radiomods.co.nz/albrecht485magnum257mods.html
Good Luck,
Dodgem250.com
1helpful
Magnum 257 6 digit display
To tune frequencies in either 10 kHz or 100 kHz increments,
press the STEP button until the desired digit is
flashing. Rotate the FREQUENCY control in either direction.
The entire frequency range of the Magnum 257
can be stepped through in 10 or 100 kHz increments.
To tune in 1 kHz increments, press the STEP button
until the 1 kHz digit flashes on and off. Rotate the FREQUENCY
control. NOTE: When stepping in 1 kHz increments,
you are limited to tuning within a 10 kHz
frequency range.
Lost buttons/1 and 2FOR 257
Yes, if this is the Magnum 257, then contact the company at 1-877-624-6869
or e-mail them from their site,, https://www.rflimited.com/Site.asp?CID=2
Hope this helps you, let me know,,, Mechanic
Operator/instruction manual
ghilger, First off, has your radio been converted to open up all the other channels(including CB)?? That has to be done first, or it's locked in the ham freq's. I think the factory manual is pretty well detailed, but i've been around radios my whole life. The mode button does the changing from am/fm/usb/lsb.Here's from the manual;
MODE: Operating Mode. Press the MODE control to select the operating mode. The operating mode is indicated on the liquid crystal display: am, fm, usb, or lsb.
* See, there is 2 different functions for each button. One set of functions are by just pushing the buttons, the other set of functions are obtained by pushing the function button first. The function button is activated by pushing in on the clarifier knob.
*Here is for saving of freq's;
Memory Save. To save in memory a specific
frequency and operating mode, select the desired mode and rotate the FREQUENCY control to the desired frequency. Press the FUNC button, and then press the M.SAVE button. S will appear on the LCD next to the frequency. While S is displayed, immediately press any of the memory channel buttons (1 - 5). The mode and frequency is now saved into memory. If the S indicator disappears before you press the memory channel button,
the information will not be saved and the process
must be repeated.
M.LOAD: Memory(Recall). To recall, any of the saved memory channels press the M.LOAD
button. L will appear on the LCD for several seconds. While the letter is displayed press the desired memory channel button (1 - 5). The programmed mode and frequency will be displayed.,
If you have any more questions about the radio, repost them here and I'll try to walk you thru them. The radio is a very good ssb rig, especially set up with a power mic. Hope this helps,, Mechanic
Top Magnum Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
