SOURCE: location of thermostat on a ford taurus 1999 for replacement
Follow the top radiator hose to the engine,the thermostat is behind the housing where the hose is connected to.
SOURCE: where is the power control module located on a 2002 Ford Taurus
hello, its under your drivers side dash , under the steering wheel.
SOURCE: Where is the DPFE Sensor located on a 2003 Ford
That is the (Differential Pressure Feedback Exhaust) - e.g. EGR Valve. You shouldn't have any trouble finding it. There is usually a metal tube from the exhaust manifold going to it,as well as one or two vacuum hoses.
It has to also, direct exhaust gas into the intake,so there is your key.
SOURCE: where is the. 2001 Ford
It's in the engine compartment, back passenger side, under cowl. here are instructions from autozone.com:
Removal & Installation
3.0L (VIN S) Engine
3.0L (VIN U, 2) Engines
