double posted. back up one.
ooops. you added were , word , is that really WHERE IS IT?
try posting simple questions.
post symptoms first. why guess? on CAUSE.
where,. try this.:
the battery Plus cable, goes directly to the starter, can you follow this cable
what does it look like, a key fact is discovery.....
first hit:
http://thumbs4.ebaystatic.com/d/l225/m/mDiB6tdy7fVpRfjwVGKSE3A.jpg
ok , i login to FSM web site (alldata.com is best) for you, so can you.
and see
qoute: Reading the manual avoids big mistakes, for sure)
Make sure you have the
anti-theft codes for the radio and the navigation system, then write down the customer's radio presets. Make sure the ignition switch is OFF.
- Before servicing the vehicle, refer to the precautions section.
- Remove the battery trim.
- Disconnect the negative cable from the battery first, then disconnect the positive cable.
- Remove the intake manifold cover
- Remove the vacuum hose and transmission dipstick.
- Remove the harness clamp.
- Disconnect the starter cable from the B terminal, then disconnect the BLK/WHT wire from the S terminal.
- Remove the two bolts holding the starter, then remove the starter."
unquote
Got a New Battery and a the OEM pin from the dealer there has to be a default way to reset the Navigation is there?
