I took a vedio by my nokia E63.and saved in memoricard. Than locked the vedio by a nokia application. now the phone is damazed. bt i can not play the vedio. the format of the vedio is .mp4.migitallock. The vedio is very important for me. what should i do?
SOURCE: Downloading mp4 files to nokia 5200
just get this software called xilisoft 3gp converter and install it.after installation you can convert to any format you like
SOURCE: nokia e63 unlock
Unlocking a Nokai E63 SIM phone requires an unlock code which you can usually get for free by calling up your phone carrier and requesting one. In exchange they will want your IMEI number which you can get by typing *#06#. Then you can use these Nokia E63 Unlock Instructions to remove your phones SIM lock to use it with any carrier you want! Good luck and i hope this helps!
SOURCE: e63 phone format
hi
Normal Reset
Using the *#7780# sequence.
It will restore ini files from ROM keeping all your data (themes, 3rd party applications, video, photos, and music files)
Deep Reset
Using the *#7370# sequence.
Completely format phone memory. Default files are cleaned up and rewritten.
Note that data found on memory card will not be altered
How to proceed
When using symbian60 v1 based phone such as nokia 7650, 3650 or N gage models these two key sequences can be entered in the same way you dial up a phone number. The phone will prompt you to enter a security code (12345 by default).
On the latest S60 phones you can try a Deep Reset, using the following steps
1. Turns off the phone
2. Press simultaneously on the green/talk, 3 and* keys and hold the 3 keys.
3. Turn on your phone
4. Wait for the onscreen Format message then can release the three keys
SOURCE: I am not able to play MP4 files in Nokia e63. I
Hello First of all i have to tell you that not all type n all size MP4 file is not played into mobile real player for particularly your E63 you have to check for 320x240 or maximum 640x320 size with mpeg or h263/264 video codac n aac or mp3 audio codec for checking this that what type of MP4 files suppots on your phone check specification of your phone on fonearena.com.
& for converting different files to specified your mobile file use any video converter like xyllisoft or total video converter.
If still there is problem then you have to go to any NOKIA costumer care for updating your mobile software. Sometime because of viruses software may corrupt and some functions may not work so check for it.
Hope this will solve your problem. ALL THE BEST...
plz. vaia. unlock my vedio anyhow. plz. plz ask me what do u want to know?
