Nokia c3 has problems
HelloFirst of all try to reduce the data which is stored in your memory card.Sometimes this problem occur due to over usage of memory.Secondly,delete some data which is stored in your phone memory.Even the problem still persist insert another memory card and try it.good luck Thanks for visiting fixya.
1 remove your battery sim card and memory card (memory card should be enough but removing all can not hurt and wait couple of minutes
2. insert sim and battery and turn it on without memory card
3. if it turns on normally turn it back off
4. insert memory card and turn it on again
This worked for me. There are also other suggestions like try to defragment the memory card... but so far it works so i am not trying that one yet
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
