It gives a lot of Soot
Sounds like you may have the thermostat turned way too high.... If you don't, check to make sure it's working correctly, like is the temperature reading correct? Is your flue all junked up with build up and crud? If so, you will need to clean it out.... You can scrap it out with a dough scraper or anything else that works for you...Also, you might check your gas connections, or have your gas co check them, and see if there are any issues with the gas connection and the amount of gas coming into your fryer. Hope this helps you.
Susan
REO
