Like computer, your phone need space to run applications /programs ( chaching). It seems you phone need more free spaces ( if there is no virus, on the phone). To get more free spaces, you need to move some programs/ applications/ files from phone memory to card ( if any). Otherwise you need to delete some files on phone memory.
Best luck
If not play the songs you change your software through nokia care or other mobile repairing shopsorplay the song one by one .go application open memory card and play song
Check out this link :http://www.gsmarena.com/nokia_2730_classic-2800.php
it only shows that max memory would be 30mb
and may put a memory stick of 2GB.
kindly check on your phones current memory status...
View the amount of memory available for game and application installations
Select Options > Memory status.
if you still have enough memory make sure your memory is set to memory card or set to both phone/memory card
check out:Synchronisation and backup page 23 of
manual:http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_2730_UG_en.pdf
you can try checking on the manual for any other query;
if you have additional question kindly leave a comment on this solution...
Thanks,
Roger
SOURCE: Music player:Not enough memory,N70
go to message menu then press options and press settings and come down to other press that and change the memory options to memory card instead of phone memory hope it works
SOURCE: When i play radio or music player in my nokia
just remove the memory card and put it back again.
SOURCE: When I try to open my music player it is showing
Bro it seems that your phone memory might be fully loaded.So delete the files which are located in your phone memory it'll surely help you.Good luck
