Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
SOURCE: I'd like to have a little diagram of the correct
unfortunatly there arent any diagrams, my best advise would be to install the fuel lines leaving excess to trim off as you route them betwixt and between. remember that the fuel lines complete a circuit and that the primer bulb does not pressure up the carb, all it does is circulate fuel through the system and makes a loop
hope this helps and good luck
