To clean the dirt and rust on your lcd screen is so easy to do.
Here are the Tools to be use,any improvise tool can do.
* you can use small,precision flat screw driver the same as a swiss knife or any.
* a clean clothe
* scotch tape
* a T6 precision screw driver or any tool that can remove the screw,even a sharp knife or swiss knife can do.
Here is the procedure on how to disassemble the upper block portion.
1. remove the battery first before dismantling the upper block portion to avoid electro-static components on your mobile, might result to a short circuit due to the used of metal tools that contacts some parts of it.
2. now at the back portion of the upper block, you can see a margin located at the bottom part centered,lift up the back cover using the flat screw driver all through the sides, some area is to hard to release because there are some hidden clips inserted.
3. upon removal of the back cover of the upper block, you can see a flex connection on the left side bottom,gently pill it up or pull the plastic to remove from the board connector.be care of that flex connector cause it is just only may from a thin,plastic parts and easy to be teared.
4. Now you can also see 4 screw, release the screw using a T6 presision screw driver then place it to a safe area, might be lose due to its small size parts.
5. carefully lift up the entire module (the board with lcd) then place it on a safe area cause the lcd might be broken when dropped off.
6. using a clean clothe, wipe the glass type cover of the housing which dust and dirt is located.as well as the lcd.
7. to remove some marks or fingerprint marks on the glass cover or lcd, use a scotch tape then place it all over the panel of lcd and glass cover by pulling up and down.
8. now assembly it and be guide and look forward for the pattern on how you dismatle all parts and position.
Take a look at some scene here on this video (just be guided on the particular portions)
Hoping this procedure is clear enough for you.. Thank you for visiting fixya...
