Hey...i have a 95 eclipse non turbo...just replaced the engine but wont start ...when i turn the key all the lights turn on the engine light comes on then turns of ....but my windshild wippers turn on but wont turn of...im not getting any power to my fuel pump and part of my engine harness
Your problem is most likely because you are describing your vehicle as a "Gs". The only similar listings in the catalog are for a "GSX". (The parts counter person probably has no clue that there is a difference) The GSX is only built in a turbo version, therefore you will not find a water outlet for the non-turbo version...it simply does not exist.
Now, if you simply describe it as an Eclipse, there are water outlets listed for the turbo 2.0L, the non-turbo 2.0L and the non-turbo 2.4L engines. You did not bother to mention engine size, so I will list the part numbers for BOTH of the non-turbo engines.
For the 2.4L engine: Compressor Works Part Number 815517
For the 2.0L engine: Compressor Works Part Number 815576
i have a 97 eclipse and when my gas light comes on i have 10 to 20 miles until i run outa gas. depending on how you car runs and if it is turbo or not. on a non turbo 420a motor w/ a 5 speed i can do this.
I have a 1997 mit-eclipse non-turbo I been have a problem of a no start.I can start the car from the ignition switch but it won't start from the key? So I change the key lock cyclinder and the house and I still have the same problem. All my light come on ,but no start with the key
