My 1.5 year old LDS5811 LG dishwasher started a grinding noise which sounded like a lack water. At first it ran with this noise. After several weeks it stopped after about 30 seconds after making this noise and then stopped displaying the error code E1. I started putting in 3 small buckets of water during each water re-fill cycle and it worked. Any help on what part needs replaced? thanks!
1E= Inlet Error
Condition>>>
Not reached to the normal
water level in spite
of 10 min. water supply
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker
I have the exact same problem and it does give error code E1 not 1E (low water).
Mine is making the same noise..but NO error code. I tried adding 2 qt water after reading this post and the noise stopped. Does that mean it may be the same thing?
The problem was that the float on the side of the dishwasher had black gunk and was sticking open causing the dishwasher to keep pumping out the water. I removed and cleaned and it worked for about 6 months. Now I'm having the reverse problem...the float is sticking close causing the dishwasher to over fill and leak out the door. I'm going to replace the float system and hope that solves the problem.
Hja8630 not working
bosch dishwasher started cycle but stopped during first part of cycle and is full of water with error code eo6 displayed
