Kodak EasyShare Z1275 Digital Camera Logo
Posted on Jun 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My z1275 will not power up. i have good batt.what can i do.
CameraR
Level 3:
  • Kodak Master 4,738 Answers
  • Posted on Jun 11, 2011
CameraR
Kodak Master
Level 3:
Answers
4738
Questions
Helped
1196079
Points
12483
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Lines in view finder and on pics. also pics come out pinkish
The problem is a faulty CCD. Replacing the CCD yourself is possible but its really a difficult task. It is cheaper to simply buy another used z1275, because a CCD can cost about the same as a used camera. You can also buy parts-cameras but you don't know if the CCD is good or not. Ebay always has a good selection of cameras..
It will turn on, ask for date set, wheather you press yes or cancel it automatically turns off
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Pressing Wide angle or Telephoto shuts camera down
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
If your cam use manufactors rechargeble batt.:
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Z1275 produces horizontal lines through images. Flash, auto, program....doesn't matter what mode.
Hi
If your Z1275 has horizontal lines going through the images you should call Kodak Technical service
the number is 18002356325 op1 op12 op2
thanks
hope this help
Byron
2answers
My kodak z1275 wont turn on
first check wether those batteries are getting charged solution is to replace the batteries as you might nave not used the camers from quite long time
1helpful
Brand new long life AA batteries only lasting 15mins
Hi there.
This is a common problem with just about any digital camera out there (even my own).
After spending loads of money on top named brands and types i found that Duracell Alkaline batteries lasted just about the longest in my camera which is a Samsung S 500. Even so i would advise that you stock on them because the camera's do tend to eat the battery power.
Good luck and thanks for using FixYa!!
EASYSHARE Z1275 Digital Camera
KODAK EASYSHARE Z1275 is a peice of ****
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
