A faulty o2 sensor will not cause a misfire. This is exhaust related, which is more than likely due to a clogged catalytic converter, which was is likely due to your misfire leaving unburned fuel to go to the exhaust, which clogs the catalyst. You likely smell a rotten egg type smell in the car at times. Your misfire is likely another cylinder. The OBDII codes are not great at finding the cylinder of the misfire in this particular car. Your best bet is to replace all 8 coils and plugs at the same time with OEM Motorcraft coils only. One bad coil makes the others work harder, meaning if you replace them one at a time, you will be constantly chasing a misfire.
