SOURCE: Toro Mower Recoil Assembly
try turning it clockwise. if it doesnt work it means the inner coil may be broken. its pretty difficult to fix those but if you would to try let me know and i'll talk you through it
Remove the recoil assembly from the machine, there are 3 machine screws.
Remove the old rope and get matching cord, make sure you get the correct diameter, usually 3/16 or 1/4 inch, and type, I believe it should be nylon braided. Do not cut the new cord.
Use a match to light the end of the cord and once it ignites, use an old rag to pull and form the end into a point.
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Gary
