Ran good then one day and cut off . put gas in carb ,run for a second . ck fuel pump wks good. need it 2run can u help......... its a 100series 105 john deer , briggs eng 19hp
It pays to check and test systematically instead of throwing new parts at a problem - a new spark plug doesn't guarantee a good spark any more than a new carb guarantees fuel is reaching the cylinder...
An engine to start and run needs: -
Compression.
A good cranking speed.
The right amount of fuel being delivered into the cylinder.
A good spark.
Everything happening at the right time.
At least one of those things is absent and we can't help you discover which...
Trash in the tank fuel line outlet. When you tilt it the trash moves and lets some gas in. Set it down and the trash goes back in the hole and shuts off the gas. No pressure to feed fuel so when you pull choke makes it run rich and then starves for gas again. Dump gas, disconnect the line at the carb. Put a clean tube (drinking straw, plastic tube, whatever will fit so you don't get gas in your mouth) in the gas line and blow air into the tank through the filter clearing the obstruction. Reconnect line then see if it runs longer before it shut off. If it does clean the tank and flush the dirt out. If that doesn't change anything then it has to be a carb diaphragm leaking and it need a rebuild kit and fuel system flush.
you say you replaced the fuse, but does the fuse have power? the gray wire at pump should have power when cranking, or for 2 seconds when turning key on. At fuel pump relay, put power onto gray wire, the pump should run if the wiring is good. if it doenst run then ck for power at fuse while power is on gray wire.
