My poulan pro bvm200vs will not start.
took the soark plug out and it was wet and smelled of gas.
cleaned the plug,replaced it and ran for three seconds.
The flywheel should have a woodruff key on it, which fits in the groove on the crank shaft. This means the timing is pre set. When setting the timing gap, use a business card between the magnet on the flywheel and the ignition module, tighten them in that position and remove the card.
Is fuel getting into the cylinder and actually wetting the plug.?
Do you have good compression?
Hello
Does it use a fuel and oil mixture?You probably did that.
Try removing the spark plug and cleaning it with a wire brush or some emery cloth.Make sure you have spark by connecting the plug wire and resting the plug on the metal motor block.
Do not hold the plug in your hand ,if you have no spark you may have a bad magneto.
