Cars & Trucks Logo
Posted on Mar 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi! My friend has got a Jaguar xj6 1997 with a 3.2Litre engine and automatic transmission. It doesnt start. Went to work,worked just fine. Dead later on the same day. Battery ok. Tried jerking the gear stick...Nothing. Checked the Inertia switch...ok. Checked for power at fuse to fuel pump relay and main ecu fuse...ok. Did a "hot wireing" to the starter by the white cable on the back of the valve cover....ok,did crank the engine,so solenoid and starter is ok.. Tried the "unlock-with-key-and-lock-with-key-hold-until-larm-activates-and-then-unlock-and-start-trick"....didnt work. Tried both keys. Heard about some wrong with starter connection problems? Grounding or positive connection? Any suggestions? Thanks! Anders
paul fairbanks
Level 3:
Genius:
  • Jaguar Master 1,151 Answers
  • Posted on Mar 21, 2017
paul fairbanks
Jaguar Master
Level 3:
Genius:
Answers
1151
Questions
13
Helped
342813
Points
2934
I assume your car is@1997 a model/year x300 a common cause of the symptom you have is a corroded/open circuit wiring at a connector or around under the washer bottle filler white connector i think its the ok to start signal from the security/locking module located below trunk fuse box the module can also go faulty. one easy test is to switch ign on if the check engine light goes off with other warning lights. start there fault finding with the wiring etc
5 Related Answers
Anonymous
  • Posted on Aug 18, 2009
SOURCE: can't get in the trunk of my 1996 jaguar xj6
Did you try the valet button under the arm rest?
Anonymous
  • Posted on Oct 11, 2009
SOURCE: cant locate fuel pump to replace on 89 xj6 jaguar
Fuel Pump Relay
Located under passenger's dash panel on yellow connector block.
TTFN.
Greg
Anonymous
  • Posted on Dec 05, 2009
SOURCE: My XJ6 Jaguar is jerking, probably from the
i think i might have had the same problem...if it does it when u get into 4th gear and then loose power then clean your fuel injectors then start putting + grade or supreme in about 2 tanks later should be running better after about 4 tanks or so my car ran like New, hope this helps
Kiri Amarakoon
  • 290 Answers
  • Posted on Jan 13, 2010
SOURCE: 00 xj8 starter will not work with key. can use
Sounds like you have a faulty ingintion/starter switch or a bad connection to the ignition switch.
Anonymous
  • 24 Answers
  • Posted on Mar 30, 2010
SOURCE: jaguar xj6 jaguar gold 1993 dashboard warning lights
Sounds like it could be the traction control light?
Acceleration, transmission, or steering issue?
How long since you replaced your Coil on plugs(COPs) and the spark plugs? On Lincoln LS with Jaguar engines,they interrupt PCM signals to throttle,transmission,etc. Just a thought. don-ohio
2002 jaguar xj8 when I drive it won't go over 3000rpm
Jaguar wont rev 3000 rpm Questions & Answers - Fixya
www.fixya.com > Forum > Tags > wont rev 3000 rpm
1998 Jaguar XJ8 won't rev over 3000 rpm ... Wont go beyong 3000 Revs s type 2001, wont go beyond 3000 Revs and it' in limp ... Question about 2002 X-Type ... My jaguar xjr8 year 2000 battery went dead started car went for short drive back ...
Jaguar engine cuts 3000 rpm Questions & Answers - Fixya
www.fixya.com > Forum > Tags > engine cuts 3000 rpm
1998 Jaguar XJ8 won't rev over 3000 rpm ... engine cuts out and shudders at 3000 rpm won't accelerateobd code p0332 2002 jaguar x type 3.0 l P0332 - Knock ... Car is boging out in park and will not go over ... driving, don't worry about it.
Rev Won't go up
www.jaguarforum.com/showthread.php?t=14662
1helpful
The engine went dead when I slow down to turn on neutral gear. what is the possible cause?
Neutral gear? Standard transmission or Automatic? If automatic
car may be smart enough to shut down. If Standard transmission
you may have a clutch safety start switch wire loose or bad switch.
My battery went dead, so i recharge it and the car starts, now my throttle doesnt work what happend?
Sounds like when the battery went dead, there was still a little power left in it, and when starting was attempted, it went completely dead. This causes the computer to automatically shut down to prevent damage to it. Starting it afterwards may require allowing it to run until it reaches operating temp (when temp gauge is in center), and then restarting one or two times. If this doesn't work, you will need a scan tool to reset pcm.
P1646 how much to repair
P1512 Throttle Position Sensor Idle Switch Sense Circuit
P1513 Throttle Position Sensor Idle Switch Sense Circuit
P1514 Park/Neutral Position Switch High Load Neutral/Drive
P1516 Gear Change Park/Neutral Malfunction
P1517 Engine Cranking Park/Neutral Malfunction
P1607 MIL Output Circuit
P1608 Automatic Transmission
P1609 Internal ECM Error
P1641 Fuel Pump Relay No. 1
P1646 Fuel Pump Relay No. 2
P1739 Automatic Transmission
P1775 Transmission Control Module MIL Circuit
P1776 Torque Reduction Request Signal
P1777 Torque Reduction Circuit
P1780 Automatic Transmission
P1781 Automatic Transmission
P1782 Automatic Transmission
P1783 Automatic Transmission
P1785 Automatic Transmission
P1790 Automatic Transmission
P1791 Automatic Transmission
P1792 Automatic Transmission
P1794 Automatic Transmission
P1796 Automatic Transmission
as you can no such code exists for a jaguar ,contact code reader manufacturer
Dies after running for awhile
you have vapor lock...try a fuel stabilizer...that should fix it
1helpful
2answers
Battery went dead, charged battery and still wont turn over
i had a 95 xj 6 with the same problem. At the fire wall on the right side is a bolt with a rubber cover on it. this cable goes behind the engine to the starter. That bolt at the fire wall my need to be replaced. find it it may be rusted or corroded. If it is, the current from the battery will stop at that bolt and not contunue on to the starter but lights and everything else will work. If when you turn the key you just hear a click or nothing. that part is 5 dollars at autozone.
2helpful
Transmission problem bmw x5 automatic
dear friend-the fact that your vehcl does not pick up speed tells me that it is slipping,there is a pressure lost in the gear box,you have to remove and rebuild as the clutches will be burnt.
Problem with 2005 Jaguar XJ8L
Hi Tracy.
Yes its a new one to me too !
I presume its an automatic model ?
Possibly the gear selection inhibitor switch is at fault, due to water ingress ?
Have you tried starting in neutral ?
Do you hear any clicking from the engine starter at all, when you turn the key ?
If you do, then suspect the starter motor at fault.
I see you posted this on Dec the 6th, so expect you have located the problem by now, if not hope I have been of some help.
Best Wishes !
John.
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
