The wheel on start up doesn't seem to locate itself. when the wheel stops both green lights are flashing. The buttons do not respond so you can't use the wheel. Is there somewhere it can be sent to be repaired? Also can you give a ballpark figure to repair this or is it better just to buy another wheel? Thanks, David
A solution from Youtube comments:
"if u realy want this wheel to work u need to open it up, and there is a rail u can move foward to lock the wheel into 180, then fire up your pc ps3 or game and let it calibrate. and it will stay in 180 (left led on)then after it has done that push the rail backwards for 900 (both leds on). and its all good, the rail is white plastic and is under the big metal bar. u cant miss it.
ive cut a hole in mine at the top so i can move the rail whenever :)"
