I already knew about the low quality of samsung products. I bought a samsung just because it was the only phone with 3g, wifi and two SIM cards in Brazil (sepetember 2011). This phone sucks. Nothing works. The samsung KIES is a joke ( a lot of error messages, a waste of time). My wife bought an LG, which is much better. I will not buy anything from samsung again.
SOURCE: Increase font size on Nokia E65 Mobile Phone
NOKIA SAYS THAT THE FONTS ARE NOT CHANGAABLE THEY ARE WRONG!
There is quite a simple way to change system fonts in the Nokia E65 phone.
The following is how I did it in my E65.
First you have to select the memory as phone NOT the memory card.
Then connect the phone to PC through the standard USB cable. When the phone prompts you, select “Data Transfer” NOT PC Suite”. Once the phone is connected you can view it as a removable drive. First check if a directory named “Fonts” exists.
If it does not exist, just create it in the resources folder. If it already exists, just make a backup copy of it.
Now, go to your PC Fonts directory (usually c:\Windows\Fonts) and do the following:
You can use any TT font I used a font called Baveuse.TTF as the bold I used the Baveuse3D.TTF as my normal font. You have to have (3) three fonts and they have to be renamed to what is below or it won’t work.
Copy Any (True Type you want) font file to:\resources\Fonts\NSSB60.ttf
Copy Any Bold (True Type) font file to:\resources\Fonts\NOSNR60.ttf
Copy again the same normal Bold (TT) font file to:\resources\Fonts\NSTSB60.ttf
The (3) Three fonts have to be renamed as above or they wont work!!!
Then just disconnect the phone from USB turn it off. Then restart your phone and put the memory back to the card and you will have the new fonts in place. This is how I did my E65 and it worked ok for me. If the fonts are to big just start over delete the three fonts and use a different font to you find one you like I like the Baveuse.TTF font its personal choice.
SOURCE: SamsungGT-S5233-A:How do i block message from a particular mobile
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
>>now you are all done.
>>no need to buy medicine for your head aches.. :-D
regards.
Testimonial: "Very much relieved ... thank you"
SOURCE: my samsung mobile inbox msg limit only 200 msges
There is nothing you can do for this. If possible bang your head 100 times on the wall so that samsung people will pity you and think again whether they are kings of the world or not.
SOURCE: message memory in samsung star S5233 model is 500
Are you sure that there's no other misc files in the message folder such as sent or outbox message? Please do check your message memory settings,. good luck..
SOURCE: samsung corby text message inbox
Mostly for all US Samsung mobile phones, all you need is to press the side volume key down/up to make the font smaller/bigger when reading text messages.
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
