Every time I watch a internet video I get a blue screen. It says the cuase of it was: watchdog.sys . I have search on the internet for answers/ solutions however there isn't any clear ones. Please help.
Hello Jeninesque, indicates the brand and model of the equipment you are discussing, in order to find the best possible solution
Check the power supply of the cameras, as well as the video connections, if they are IP cameras, search camera by camera independently, or get in touch with who installed the cameras
I wait your answer
Greetings Franco Dosil
Hola Jeninesque, indica marca y modelo de los equipos que estas comentando, para poder encontrar la mejor soluci?n posible
Revisa la alimentacion de corriente de las camaras, como asi tambien las conexiones de video, si son camaras IP, busca camara por camara en forma independiente, o ponte en contacto con quien instalo las camaras
Espero tu respuesta
Saludos Franco Dosil
I found the following for DVR Vmax Flex: Reset procedure is as follows, Press and hold the OK button on the remote for 45 seconds, it will beep many times, a screen will pop up and ask you to reset, select YES. The reset will default it to factory, which is No Password at all. If this is not the info you're after, you can choose a method to contact Digital Watch Dog shown on their webpage:
http://digital-watchdog.com/
I've never seen a watchdog.tion error but watchdog errors can be set up on some CMOS when the 5v power from the power supply is bad. I can't find anything on your specific error tho but I would try a different Power Supply Unit.
its a fault caused by memory but not because of memory.
Either check ur hard drive with a utility(chkdsk)
or remove hd and clean pins and connection(small shaving brush is ideal for this) replace hd.
It could be bad sectors on drive and if not solved sooner than later ur hd can become damaged beyond repair.
if you have a xp disk,boot up with disk and select "r" for repair then once in dos platform type in " chkdsk" this is the easiest way there are other ways but can cause problems.
