Heating & Cooling Logo
Posted on Mar 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to change light bulb and cannot undo cover.
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Mar 18, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2105259
Points
14643
It would help to know, what it is that you're trying to change the light bulb in?
Light bulb replacement
https://www.google.co.uk/search?q=Hitachi+CP-X253+bulb+replacement.
Fourth result.
"User manual" link on that page.
Page 48 of that document.
Turn off projector and remove power, undo screw on cover, take cover off, undo screws on bulb housing, remove bulb, put new bulb in, do screws up, replace cover, do up its screw, reconnect power and turn projector back on. Go into menu, advanced, option, lamp time, and push the up button to reset hours.
I literally just read that out of the manual.
Change Dualis brake light
Simple, undo the 2 nuts that hold the glass tail-light in place, pull the frame towards you, unclip the 3 black clips that hold the plastic case in place, turn the bulb and pull out.
Replace bulb, test brake lights and put the casing back together.
Just done the wife's car, no problem and brought extra bulb incase another goes.
How to change the light bulb of my brother xl2600i
on the left of the machine you should see a plastic plug, gently pry it loose with a small screw driver & it should show a hidden screw, undo the screw & the plastic cover should come off, to replace the bulb, the replace the cover & screw & plastic plug
I need to take out the bulb for the tag light and I can not figure out how to get the cover off or get the bulb out. I am scared I will break the cover.
you need to go into the trunk remove the carpet from the tail light area there should be some thumb screws you need to undo them then slide out the tail light. or some models you can access the light bulb just by moving the carpet from the tail light area. hope this helps!!!!!!!!
1helpful
How do I change a brake light bulb in a 1999 c70 volvo?
Welcome to FixYa.com
Brake Lamp Replacement
Location of the lights
The illustration shows the locations of the lights on the RH side. The LH side is the same but
mirror-reversed.
The lights have the following functions:
- 1 +1 = Parking light Fail light
- 2 = Reversing light
- 3 = Fog light LH side only (LHD cars)
- 5 = Direction indicator
- 6 = Brake light
Tail light changing bulbs
Ignition off.
Open the cover in front of the tail light
Undo the wing nut and take out the lamp holder.
Change the defective bulb.
Fit in reverse order.
Check that all bulbs lamps are intact and in working order.
Replacement of tail light cluster
Note! If a new tail light is to be fitted, the sleeves must be ground down 1.5 mm.
Open the cover in front of the tail light Undo the panel partly in front of the tail light Unplug the
connector for the tail light Undo the four nuts securing the tail light see illustration.
Pull the tail light straight out. Fit in reverse order
Note! check the sealing and fit on reassembly.
Check that all bulbs lamps are intact and in working order.Thank you for Using FixYa.comKind Regards, LeeYour FixYa Expert and Master Technician
Im learning how do i replace a turn singal bulb on the back
you will have to remove the cover open up your back hatch and see if there is a couple of screws on the inside that reach to the light cover then undo them pull the cover off and you should be able to reach and change your bulb hope this helps let me know and good luck
3helpful
How do i change the light bulb & where can i get the bulb
In most microwaves, the bulb can be accessed by removing the main cover. Unplug the oven, undo the screws that hold the metal cover, and locate the bulb. If the bulb is a standard screw type, it can be found at your local home center. If it is a specialty type, then you can try looking at repairclinc.com
1helpful
2answers
How do you change a rear signal bulb in a 1990 toyota celica?
hi ders a plastic cap on the top of your rear light when u open the boot door,take out the screw under it and pop the cover off the orange piece on the side n unscrew the bolt..carefuly...it should just pop off then
Changing the dome light bulb on a 202 Dodge Neon
you should be able to slide the cover off some times you have to squeeze the sides to undo the cover
7helpful
2answers
Changing oven light bulb
The manual states to turn the cover counter clockwise. I was able to turn it about an inch and then it stopped turning. You really have to apply pressure, but it will turn more. It is similar to a tight light fixture. I was worried about breaking it, but it did finally loosen. I believe the replacement bulb is a 40 watt mini oven bulb also...
Hope this helps!
Top Heating & Cooling Experts
Paul Carew
john h
