Distance from consumer unit to shower including drops from ceiling to units approx 12metres
Propose removing bath and fitting 9.5 0r 10.5 electric shower at end where taps were.This is tiles on a studded panel and I am hoping to be able to push up a flexible plastic cold water connector pipe to the shower fitting location, I don`t know whether the tiles are on plasterboard or plywood. There is a blanked off 15mm mains water pipe at the base which I am intending to connect to.
Electric cable to come to shower position from loft above
Any observations on securing the shower fitment would be welcome!
Proposed size of cable 10mm
Does this run from consumer unit (trip type) to ceiling control switch (45am pull switch)to shower fitment?
Will tiling be waterproof enough for shower? or would you suggest raking out joints and regrouting?
Many thanks in advance,
Roger
PS done it before but needing a refresher any advice welcome
