Remove the #7 spark plug if it does not look fouled start the vehicle with the plug still connected and look at the ground electrode for any spark it should be a white arc which indicates a high intensity spark if its orange/red it is a weak spark. If you get a poor spark try removing any other spark plug and test it on the #7 coil wire If you still get a poor spark then your plug wire or ignition coil is to blame and would need to be replaced. You can swap your plus wire to test it in the same way as well. hope this helps
