There may be possible damage of processor or mother board.First of all check is there warranty period exists? If so! Consult with theauthorized dealer to rectify/replace the thing what ever may be. AND if not warranty whatsoever, let we checkthe system step by step at our own. Unplug your system. Open the casing ofsystem. Disconnect each and every thing within the system. Pull out RAM, PROCESSOR,any mounted cards. Use compressed air to make your system dust free. Now placethe processor and RAM in their places. Only keep only connected motherboard.Start computer by plugging it on. Note! If you have more than one RAM CHIPcheck one by one and also one at each available at memory bank (slot). Checkall the fans first working properly. There may be at least two fans one in thePower supply and other one on the processor. Check out any beep sound if any. Youshould also try to also check with an other Power supply. This is the processfor locating problem. When display appeared reconnect all card one by one andcheck. At the end NOW connect Hard disk and boot your computer. You will bedone INSHALLAH. Forget me not. AMSHAD
When the lines are showing, check to see if you can see them with the on screen menu being displayed, if you can then it is the DMD board, if you cannot then it is just the digital board.
