I need step by step GPRS settings process to connect to interent through my HTC touch P3452. Currently i am using vodafone network.Any suggestions are welcome.
Vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
Hutch-WAP settings should be:
Connects to: WAP Network
Access Point: portalnmms
Rest settings are default.
Then, in Phone Settings>Connections,Select Proxy and edit the Hutch-WAP Proxy.
Connects from: WAP network
Connects to: The Internet
Proxy(name : port): 10.10.1.100:9401
Type: HTTP
In Connections>Menu>Advanced,
Select:
Internet Connection: Hutch-WAP
Work Connection: Automatic
WAP connection: Hutch-WAP
Secure WAP: Auto.
Then in Internet Explorer, Menu>Tools>Options>Connections:
Check Automatically detect settings.
Select Network: The Internet
Well dear,
Vodafone has a policy of giving free vodafone live to certain handsets only, the likes of sony erricson, samsung, nokia...you can check that on the site itself. well you'll have to puchase the vodafone mobile connect scheme, in which you pay a monthly rental and then even connect your laptop with phone.
So no free internet on phone i.e. you pay rental+usage charges...
I have installed the same for Asus. great!!!
Here
First go to Settings -> Connections -> create a new setting
Create a name: Hutch GPRS
Select a modem: Cellular Line (GPRS)
Access point: portalnmms
User name: (empty)
Password: (empty)
Domain: (empty)
Advanced:
TCP/IP tab
(use server assigned IP address)
Servers tab
Primary DNS: (empty)
2nd DNS: (empty)
Then go to Settings ->Proxy SettingsConnects from: Work
Check Box select :This network connects to the internet
Check Box select :This network uses a proxy server to connect to the internet
Advanced
HTTP Proxy (Name:port):10.10.1.100:9401
WAP Proxy (Name:port):10.10.1.100:9401
User Name: (empty)
Password: (empty)
Thats it you should have free internet with Internet Explorer, however the Weather does not work
I will modify settings after i figure out how to make that work.
Lizen me, Honestly I say you to enjoy it while it lasts na ***in
how to get gprs work in htc 3450 touch
I couldnt get it working. plz help me out.
