I'm tryna play video games like the rugby08 PC game but it shows an error when i try start...im guessing its the VGA(compatible) driver is not installed. Can you help me out pls.
Jonah.
You may need to install or reinstall your video driver. You can easily do this by finding out what video chip or card you have and then going to the correct location to download the most up to date driver.
To find out what video card you have, go here: Start-->Run-->type in "dxdiag" and wait for the tool to load. Then navigate to the "Video" tab. Then in the "Chip Type" field you will see what video card you have. Once you have that information, I can point you to the proper location to download the driver.Hi,
You can't post conmments that contain an email address.
Try earlier versions of 3D games.
Your computer is a somewhat older model. So try playing 3D games released around 2000-2002.
Try NFS 6 or lower, GTA version 2, IGI 1 & 2 etc.
If even they don't work, try replacing the VGA card with a compatible but better VGA card (Cards from nVidia might be a good option).
You would need to have your video driver updated. If it's an onboard VGA you can try to go to the motherboard manufacturers website or if it's a separate VGA you can go to the VGA card manufacturer webpage and download the driver from there.
Or it could also mean that the VGA you are using doesn't support D3D which makes it incompatible to the game that you wanting to play.
VGA compatible device not found represents that either your bios couldnt recognize the VGA hardware or your OS pnp service couldnt initialize the Hardware for VGA. Either these cases, we should look for the level of Hardware detection at which it fails. If its an onboard VGA device, you may need to replace it with an addon VGA card based on the Mother Board compatibility and then try install it again. This should solve the issue.
ok this is a simple easy solution.... however you can go to www.java.com and download the updates....
are you using the newest version of IExplore? if you want you can use Firefox or GoogleChrome! they are all updated.... some free games require Certain Computer Diagnostics in order to be fully compatible with the computer....
if you had a current list of games that you were wanting i could give you more of a definate solution!
There is the divers if u running XP as OS, if not change the OS to that one you run
Im not sure that the issue is the 7000, it can also be your memory.
How mutch memory do you have in your pc?
Upgrade the momory solve a lot of problems whit gaming.
Try adjusting the hardware acceleration in the display properties, then in the game settings. If this doesn't fix it, then there may be compatibility issues between the game and the video drivers.
Mike,
Good holidays
This particular problem, need a particular atention, some games show this problem, when the Video Card is not supported, or video driver, is not updated. you should see if your version of drivers, are updated, and Direct X to 9c. according with recomendation on the game programming. (time to change to a good video card) or download any update for this game sometimes should fix problems.
